Old 12-08-2012, 12:50 PM   #1
Seabrook Island , South Carolina
Water pump not priming
I have a 2012 Interstate 3500. I used the water pump one or two times before for a short while and it worked fine. The last trip I took it would not work. The pump is running but no water comes through. Airstream support diagnosed it as the pump is not priming itself. They said since it is still under warranty I can just take it in and get it fixed or replaced at no charge. Problem is the nearest dealer is over 2 hours away. They suggested taking the pump apart to see if something is clogging the pump. Also suggested taking the screen out to see if it is plugged up.
Before I start taking things apart, has anyone else had this same problem? If so, what was the solution?
Asheville is offline   Reply With Quote
Old 12-08-2012, 01:16 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Had that problem with mine. The nice folks at Airstream of Mississippi, AKA Foley RV Center, were able to prime it for me in just a couple of minutes without taking anything apart except to remove the bottom drawer so they could reach the pump. Not sure exactly what they did, though. Guess I should have set up a webcam or something so I could watch. There's no other way for two people (the mechanic and me) to see inside the drawer opening at the same time.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-08-2012, 01:18 PM   #3
Lily&Me's Avatar
Normal , Illinois
Is it everything that won't run----shower and sink?
We have had reduced flow when sediment has clogged the filter, I would sure check and clean out that screen.
Also check and clean the little screen in your sink spigot.
If you had bad water, those screens can clog up quickly. Not a terribly big deal to remove and clean them. We have done it and are not terribly handy.
Maggie
Old 12-08-2012, 02:05 PM   #4
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
New vehicle shouldn't have trash in line, try loosening closest fitting on the pressure side of the pump. it shows arrow or reads output. If I run out of water on the boat, the pump sucks air and then won't pump water, have also managed to open valve closest to the pump and with a full tank it will self prime. Make sure your tank is full or at least has a level above pump input.
Old 12-08-2012, 03:02 PM   #5
Will try that but I have no flow at all so that may not be the problem. Thanks
Old 12-08-2012, 03:05 PM   #6
Airstream suggested I fill tank to over flowing which i did and it still would not pump water ( although pump was running). I will try loosening valve. When you say pressure side do you mean the incoming or outgoing side? Thanks
Old 12-08-2012, 03:20 PM   #7
Pressure side is the outgoing side. Suction side is the tank side.
A sudden thought… The pump is supposed to be self-priming, but it won't pump against air pressure, and that may be what's preventing it from priming. Open ALL the faucets, about midway between hot and cold, THEN turn on the pump. With an outlet for air to escape, the pump may prime itself.
If that doesn't work, THEN try disconnecting the pressure side.
WBCCI #1105
TAC LA-4
Old 12-08-2012, 03:32 PM   #8
Lothlorian's Avatar
Loganville , Georgia
I had this problem and had a RV tech check it out. He had a theory before he looked at it and went to the problem immediately. There was a very small amount of air entering in water tank side and he put plumber tape on the fitting and reattached it. I never have a problem since.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 12-08-2012, 04:52 PM   #9
1977 Argosy 24
Milltown , Wisconsin
Like was said above, make sure the faucets are open when trying to prime the pump, so the pump is not pushing against an air cushion.
ventport is offline   Reply With Quote
Old 12-08-2012, 06:32 PM   #10
2010 27' FB International
La Crescent , Minnesota
A pluged discharge line. A failed pump. Most likely sucking air through the inlet line.
Jay
mjayjensen is offline   Reply With Quote
Old 12-08-2012, 11:46 PM   #11
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
After refilling the tank last spring, I had to use compressed air to get it to prime. Stuck the air line in the fill port and wrapped a rag around it and press and released the air nozzle several times. The faucet were open. This was what my dealer recommended and it worked.
Old 12-09-2012, 04:38 PM   #12
Airstream suggested this also. I will try this before taking anything apart. Thanks
Old 12-10-2012, 07:37 PM   #13
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
I had the same problem. Jim P. at Airstream CS suggested SLIGHTLY pressurizing the tank with an air compressor. This got it going right away!
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 03-18-2013, 04:24 PM   #14
jquayle's Avatar
2013 Interstate Coach
Napa , California
Same problem.
Dealer told me I needed the water level completely full, but that didn't help. They got it primed and advised they had found a lot of plastic shaving in the line.
Drained all the water during a ski trip to Tahoe to prevent water freezing in the lines. After I filled it back up it wouldn't prime.
Dealer walked me through checking the filter screen (most plastic shavings, but removing them didn't help)
I was able to get it primed by messing with the drain valves open and closed until it eventually primed. Overall I'm not thrilled with the performance of this units ability to 'self prime'.
Pressuring the tank as recommended in other posts may work great, but that's not really 'self priming' either.
jquayle is offline   Reply With Quote
