Old 06-22-2019, 10:18 AM   #1
Water pump do-over (T1N Interstate van)
This project has been on our to-do list for almost *five years*!!
In the T1N (first-generation) Interstate, the water pump is located under the kitchen galley counter on the forward (left) end.
As was the case with many other aspects of the T1N build, Airstream made an unconscionable mess of the space. Electrical wires and water lines flung every which way in a big rat's nest. It may have functioned, but the workmanship was ghastly, plus the messy installation resulted in the forfeiture of what should have been a cavernous storage space.
For almost 5 years, I have been squeezing my little laundry basket in there with the pump.
But then the pump seal started going bad, resulting in backflow and the noisy pump actuating at all hours of the night. LB_3 attempted to repair it, but that effort was unsuccessful, and not only that, the pump actually got louder. So then he tried to quiet the pump with noise attenuating materials, which made an even bigger mess of the space.
So we bought a new pump. And, if we are going to go to the trouble to install a new pump, we might as well clean up this area once and for all, so that we can finally make use of it for storage the way it ought to have been used all along.
I don't yet know how this project is going to work out, but here's the "before" pic of said rat's nest:
InterBlog is online now   Reply With Quote
Old 06-22-2019, 11:39 AM   #2
"There's scope creep," LB_3 announced grimly. But at first, he wouldn't tell me what it consisted of.
This. The diagonal end-cap unscrews from the cabinetry without disturbing the remaining structure. If that thing could be trimmed out and REATTACHED WITH HINGES, it would dramatically improve storage access in the galley's butt end. All that space you see there top and bottom is very difficult to reach and organize via the door that opens into the center aisle.
The cabinetry is quite solidly constructed. It wouldn't require much bolstering to have this become a functional door rather than a fixed panel.
Maybe one of those doors that latches and unlatches by pushing on it, so it would be nearly invisible. Push on it, and it pops out. Push on it again and it re-latches. I don't know if that could be accomplished with this geometry, but it would be cool if it could.
Old 06-23-2019, 07:02 PM   #3
I feel like throwing up in my mouth - I can't believe we lived for almost five years with a water pump that sounded like a bloody World War II machine gun. WHY?!
This pic below doesn't give a good feel for what this space now looks like - the 3rd dimension is lost. The pump is suspended from the underside of the shelf via T-nuts and brass screws. It hangs down about 6 inches and everything else is now relocated up against the butt end of the fresh water tank. But the pic sorta makes it look like it is all in the same plane.
LB_3 engineered some vibration-dampening measures to go with the now-hanging water pump. This is a story-within-a-story, but those measures include four rubber pool cue bumpers inserted into the suspension mechanism. We acquired those bumpers some years back when he built me a custom six-quarters chef's cutting board with really robust non-slip feet (the pool cue bumpers made far better feet than anything else on the market).
Anyway, this is just an interim pic, but my mind is blown by how QUIET this thing is (and it's a Shurflo, same brand as the one we took out).
See the screw holes remaining in the floor, where that hot mess of non-workmanship originally consumed most of this precious storage space.
More to come on the cabinetry finish work.
Old 06-23-2019, 07:36 PM   #4
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
Very nice. Looks like a lot more useable space without all that mounted to the floor. Are you planning to cover it? To avoid anything being stored there to damage wiring or the pipes?
On the door clips. I saw something similar being used in the new 2020 AI-19... well, now that I think about it... those are different... I had to pull the panel to remove... not like the push and click that you are going to use...
ID:	344238   Click image for larger version
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 06-23-2019, 07:36 PM   #5
Missed the edit window -
My husband wanted to see more of a true before-and-after comparison, so this is closer to being that (I had to back out on the lower pic to show the hanging water pump).
Old 06-23-2019, 09:23 PM   #6
2012 Avenue Coach
Corpus Christi , Texas
Space for free! Quite an welcome addition, especially in a class b.
My shoulders ache for LB_3.
rowiebowie is offline   Reply With Quote
Old 06-24-2019, 07:30 AM   #7
wachuko's Avatar
Orlando , Florida
Yes, second set of photos shows the difference much better. Every bit of space that can be recovered counts!
Safe travels!
Wachuko
WBCCI #26769
Old 06-24-2019, 12:17 PM   #8
Tincampers's Avatar
Sneedville , Tennessee
<rant>I swear it seems like AS goes to great lengths to make the biggest mess they can. Where has the pride in workmanship gone? Get it out the door, fast. Let the dealers fix this mess later. Go, go, go. </rant>
Tincampers is offline   Reply With Quote
Old 06-24-2019, 12:54 PM   #9
I see your rant and raise you some female-dogging.
WHUT is my biggest pet peeve? The fact that Airstream used some of the best furniture-grade cabinetry stock available, no less than 8-ply (I am not even sure it is made any longer), but DID NOT SEAL THEIR CUT EDGES, which would have cost just a few more minutes of labor, but saved so much for the end-user.
As a result, even one glass of water spilled on the floor is a disaster. In 13 years, we had probably 3 minor water events. One Airstream-derived PEX leak, one minor leak before our ownership, and one other dribble that came from refrigerator condensation running across the floor to the opposite side, and this (below) is what happened to the bottom of our diagonal panel, the one that I took to a cabinet-maker this morning to have trimmed down so that it can become a door. This is the piece he chopped off so that the door can clear the floor (and my Flor carpet tiles) as it hinges.
It's going to take me a few days to prep and properly seal that whole panel, so the reveal on that part of the project is still to come.
Old 06-24-2019, 10:21 PM   #10
2012 Avenue Coach
At least that nasty bottom edge is gone for all eternity. Won't be missed. Nope, not even a little.
Old 06-25-2019, 05:18 AM   #11
Just an old timer...
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
And let's not start on failing to paint screw holes in the body leading to body rust around pretty much ANY and ALL of the places they cut holes for utilities.
*sigh*
AIR 2053 Current: 2004 Airstream Interstate "B-Van" & 2006 Born Free 32 RQ Kodiak Chassis
Old 06-25-2019, 05:31 AM   #12
*sigh*
Yes. There are historical threads on that, too.
Old 06-25-2019, 10:23 AM   #13
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
*sigh*
85MH325 - Sorry to hear. But my unit has ALL wounds, screw holes, exposed screw threads, and body penetrations painted. Even rivets were painted. I specifically ordered the "Rustproofing Option" Few pics below from a folder full of undercarriage pics.
ID:	344464   Click image for larger version
ID:	344466   Click image for larger version
ID:	344468   Click image for larger version
Alex AVI is offline   Reply With Quote
Old 06-26-2019, 07:12 AM   #14
Thank for feeling my pain.
LB_3 is offline   Reply With Quote
Electrical issue '04 T1N over-seat lighting 85MH325 Sprinter and B-van Forum 7 04-11-2019 10:22 AM
T1N Interstate fresh water pinhole leak InterBlog Sprinter and B-van Forum 9 01-27-2019 03:13 PM
2007 Interstate T1N rear sofa house battery remove and replace bugsbunny Sprinter and B-van Forum 1 07-15-2016 10:28 AM
Retrofitting solar in a T1N Interstate InterBlog Sprinter and B-van Forum 45 02-22-2016 12:56 PM
Overhead Shelf for T1N - Airstream Interstate 2005 lizt1011 Sprinter and B-van Forum 14 02-10-2016 04:36 PM
