Old 10-19-2014, 07:18 PM   #1
FunWaggin's Avatar
2014 Interstate Ext. Coach
Raleigh , North Carolina
Water pressure regulator
We are proud new owners of a 2014.5 AI. I am wondering if the AI has a built in water pressure regulator? I recall the sales guy mentioning it but I want to be sure I understood correctly.
FunWaggin is offline   Reply With Quote
Old 10-19-2014, 07:25 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
It is built into the external city water receptacle where you hook up. I think the receptacle says it is a pressure regulator there on the outside.
Doug and Cheryl
Old 10-19-2014, 07:27 PM   #3
FunWaggin's Avatar
Thank you for the rapid reply. We are heading out tomorrow and feel better knowing that.
Old 10-19-2014, 07:34 PM   #4
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I started to use one now in addition to the one in the AS as I believe (although not totally sure) that high water pressure damaged one of my water hoses
PharmGeek is offline   Reply With Quote
Old 10-19-2014, 07:59 PM   #5
dkottum's Avatar
Pharm, your water hoses are outside the trailer and not protected by the built-in unit. There is a good chance your hose damage occurred from expansion within the hose from heating of the sun, so a pressure regulator at the campground spigot would not have protected that either. There is really no reason to use an additional pressure regulator.
Doug and Cheryl
Old 10-20-2014, 06:00 PM   #6
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Ohhhh - I failed to consider that - I guess in hot weather if off and about can turn off and unscrew ?
I don't see why high pressure from the spigot could not damage the water hose (probably a dense moment)
Old 10-21-2014, 07:34 AM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Physics: Water only expands by 1.25% when heated by 100 degrees, as long as you don't heat it enough to boil it. That's not enough to rupture a hose, not even a hose that has been softened by direct exposure to the sun.
It has to be the pressure in the hose, especially when you're not using any water so all of the faucets inside are closed and the pressure has nowhere to go. It's force of habit to open the spigot at the service pedestal all the way every time you hook up, but if municipal water pressure is unusually high, you can just open the spigot partway and thereby reduce the pressure in the hose.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-21-2014, 07:39 AM   #8
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
You'll only reduce the amount of flow by not opening the spigot all the way. With everything in your camper turned off, the pressure will build to whatever the supply pressure is, even if you barely crack open the spigot. In electrical terms, it's like voltage and current. You still have the same amount of force pushing it (voltage) just not as much flowing through it (current). To reduce the pressure on the hose, you have to put the regulator on the output of the spigot...
-Red
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 10-21-2014, 07:42 AM   #9
You're right. Just goes to show that it's a good thing I'm retiring at the end of the year if I keep having senior moments like that.
WBCCI #1105
TAC LA-4
Old 10-21-2014, 07:44 AM   #10
Panama Red's Avatar
Obrien , Florida
Lucky dog! I'll take those senior moments if it means I get to retire... Just under four years now.
-Red, getting short-timers a little early...
Old 10-21-2014, 07:49 AM   #11
dkottum's Avatar
I've had a hose expand a permanent balloon at home lying in the hot sun when the supply spigot on the house was off and the spray nozzle was also off trapping whatever city pressure was there, then softening and adding the thermal expansion of the sun.
It was a cheap hose, like the ones rv's use. I don't know what else could have caused it.
Doug and Cheryl
Old 10-21-2014, 07:52 AM   #12
dkottum's Avatar
Protagonist. By the way, congratulations on your upcoming and soon-to-be retirement! Senior moments only mean life is less stressful, it's wonderful.
Doug and Cheryl
Old 10-21-2014, 08:14 AM   #13
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Even though the Airstream has an internal water pressure regulator, I still use an external one attached to the water supply spigot at the campground. I am probably being overcautious but it just makes me feel better.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 10-21-2014, 09:25 AM   #14
dkottum's Avatar
Brian, I used a second one for awhile too, then asked myself why. With no good answer I got rid of it.
Doug and Cheryl
Water pressure regulator? yukionna Fresh Water Systems 7 06-16-2010 10:03 PM
Help!! Need access water pressure regulator Crawdad Fresh Water Systems 5 07-15-2007 02:16 PM
Water pressure regulator...from factory? Kistler Our Community 6 07-14-2007 09:29 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
Any PLUMBERS out there?? Pressure regulator, water pump questions SmokelessJoe Water Heaters, Filters & Pumps 65 01-11-2007 03:01 PM
