Old 10-21-2014, 10:29 AM   #15
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Originally Posted by dkottum View Post
It is built into the external city water receptacle where you hook up. I think the receptacle says it is a pressure regulator there on the outside.
Are we sure that the Interstates have the built-in regulator?
Old 10-21-2014, 10:55 AM   #16
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
The 2014 Interstate Parts PDF, which I downloaded from the Airstream website, does mention a "City water fill w/regulator, chrome".
Old 10-21-2014, 11:01 AM   #17
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
My first time on my Alfa, I ran an external pressure reducer into external water filter into the built in PR, and lived with weak flow from the shower.
Once I realized there were two inline PR's, I pulled one and got more than the dribble. The water pump had better shower flow.
My new EB the water inlet/PR started leaking back in Jan. I pulled it from the skin, tightened it (4 screws on two piece plastic construction) and then left it loose to dry out for a couple of weeks. It started leaking again this month, so I replaced it on my dime, cheaper than a trip to Tucson for warranty.
I'm keeping the old one to seal up with silicone as backup.
"Chip Tank" is in Flagstaff Az.
CDONA is offline   Reply With Quote
Old 10-21-2014, 04:35 PM   #18
Newbie
joemikeb's Avatar
2013 Interstate Coach
Fort Worth , Texas
My 2013 came with an external pressure regulator in a plastic bag along with some other small items such as the hose and nozzle for the external shower. I use it and have no low water pressure problems.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
joemikeb is offline   Reply With Quote
Old 10-21-2014, 04:38 PM   #19
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I use external as well and water pressure is un affected as far as I could tell
Never bad a problem with water pressure yet
I still am not clear why high pressure at spigot could not damage a water hose
PharmGeek is offline   Reply With Quote
Old 10-21-2014, 06:18 PM   #20
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
This is from your (2014) Interstate Owners Manual:
"Your plumbing system has a built in pressure regulator to protect your lines and faucets from extremely high pressures on some city water systems. An after-market external regulator is not recommended, as it could lower the water pressure at the inlet and thus to your faucets and shower."
Doug and Cheryl
Old 12-19-2015, 07:19 AM   #21
A post-script with a note on older Interstates...
Initially, I didn't think much about this issue other than I grabbed a regulator in a camping store just in case there was a question about it ever being needed for some reason. The 2007 owner's manual has the same advisory verbatim as what was quoted above for the 2014 manual. The parts manual doesn't supply any technical details other than to suggest that said regulator is integral to the fill apparatus installed in the side of the Interstate.
This week I saw this type of sign for the first time in a campground, so I inserted the external regulator ahead of the shore line. Even if it will not reduce static pressure for the Physics 101 reason given in the comments above, it's still nice to have some information regarding the stated pressure - it is really high such that I maybe ought to keep an eye on it, or is there just the potential for it being high?
In this case it proved to be a non-issue, but I think I'll leave the regulator attached to the line so that I can compare to future pressures.
Old 12-19-2015, 08:41 AM   #22
Muskogee , Oklahoma
Actually, there is.
I posted this some time ago. My 2011 leaked under high pressure at the plastic intake regulator. After removing the refrigerator, I found this:
All that is standing between you and a flood is a cheap, plastic regulator held together with four screws. That's it. In my case, the device leaked because the screws, over time, either loosened, or never had been, fully tightened. Didn't matter as the damage was done. But even without that issue, the regulator itself is simply not very robust. I wouldn't trust it.
Regardless of what Airstream suggests in the manual, using a quality (i.e., brass) regulator at the tap won't cause a problem under normal pressure. And, you won't have to rely on a very cheap and flimsy plastic regulator to keep from flooding your van. If it does cause pressue issues, you can simply remove it from the line. I'd rather be over-cautious than risk a major flood if the plastic regulator fails.
But if you come to a park that has extremely high pressure, you are rolling the dice that what happened to me will happen to you. If you want to stack the deck in your favor, use a separate regulator at the tap.
Pharm, your water hoses are outside the trailer and not protected by the built-in unit. There is a good chance your hose damage occurred from expansion within the hose from heating of the sun, so a pressure regulator at the campground spigot would not have protected that either. There is really no reason to use an additional pressure regulator.
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 12-19-2015, 10:06 AM   #23
I remember that photo - part of this discussion is in another thread. The next time I bring our Interstate out of storage, I'm going to look at exactly what apparatus is associated with our city water port. When we did our black/grey water vent line repair almost a year ago, I noticed the incoming water line; in fact I took a Sharpie and marked something like "City Water In" on the inside of the bulkhead under the cabinetry, so I would not forget. But I didn't note whether it actually had any regulator-like device associated with it, or whether there was plastic vs. brass or some other material.
Water pressure regulator? yukionna Fresh Water Systems 7 06-16-2010 10:03 PM
Help!! Need access water pressure regulator Crawdad Fresh Water Systems 5 07-15-2007 02:16 PM
Water pressure regulator...from factory? Kistler Our Community 6 07-14-2007 09:29 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
Any PLUMBERS out there?? Pressure regulator, water pump questions SmokelessJoe Water Heaters, Filters & Pumps 65 01-11-2007 03:01 PM
