Old 09-30-2016, 06:41 AM   #1
Blackpearl's Avatar
2014 Interstate Ext. Coach
Charlotte , North Carolina
Water hookup, 2014 AI
Hello. I'm suspicious of hooking up to the campground water line after doing so for the first time and then within minutes finding a leak that ran a small amount of water under the bathroom that trickled into the hallway. I had always used the water pump in the past and chose to refill the fresh water tank. I never had any leaks until we hooked up the water. Any other experiences like this? Or probably just coincidence? Thanks!
Blackpearl is offline   Reply With Quote
Old 09-30-2016, 08:00 AM   #2
Lily&Me's Avatar
Normal , Illinois
It might be a water pressure issue.
I find it much simpler to fill my fresh water tank as needed, rather than hooking up to water, anyway.
Not all the on/off with the connectors.l.too tight, not tight enough and leaking, etc.
Maggie
Old 09-30-2016, 08:44 AM   #3
FlyFishinRVr's Avatar
2017 Interstate Lounge Ext
Northern , California
Maggie
+1
Not sure if your year has a built in pressure regulator, but it's always a good idea to use a high quality external regulator at the campground spigot just to make sure their pressure doesn't overwhelm your onboard systems.
FlyFishinRVr is offline   Reply With Quote
Old 09-30-2016, 10:30 AM   #4
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Probably should search out the leak since even the relatively low pressure of the on-board pump could be enuf to cause the leak to seep gradually and over time cause some undesirable effects.
Old 09-30-2016, 03:02 PM   #5
BUTLER , Pennsylvania
My 2014 had a similar leak it was the hose that connects to the bathroom faucet. On the outside wall of the bathroom there is a removable panel. Take out the screws and tighten the connections. You'll either feel the connection wet or see it dripping.
BOBCONEYBEER is offline   Reply With Quote
Old 10-01-2016, 07:51 AM   #6
Blackpearl's Avatar
Thank you everyone for taking the time to reply. This all makes sense and is great advice.
Dish tailgater hookup for 2014 23fb international Ramblingman Electrical - Systems, Generators, Batteries & Solar 16 09-23-2014 01:55 PM
Outside water hookup question. 68 Suburban Fresh Water Systems 6 10-05-2013 02:25 PM
City Water hookup & Fresh Water Tank? Driver1 Fresh Water Systems 3 02-17-2009 03:28 PM
Is this the city water hookup? Stefrobrts 1966-68 Caravel 7 05-06-2003 10:13 AM
Hose for gray water to sewer hookup?? eikel1we Waste Systems, Tanks & Totes 12 03-11-2003 01:49 PM
