Old 11-07-2013, 06:45 PM   #1
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
Water heater use in the winter
Was wondering if you use you rig in the winter do you use the hot water heater?
PSchw is offline   Reply With Quote
Old 11-07-2013, 06:50 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Yes, unless you have the rig winterized ... in which case the water systems and water heater would not be available for use.
Some people who, after have winterizing their rig, and end up using their rigs occasionally in the winter, leave the rig winterized and just don't use the bathroom facilities or the water systems. You can't have the water heater on in this case either.
TB & Greg and Abbey Schnauzer
#3954
Old 11-07-2013, 07:22 PM   #3
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Winter Use of Toilet
Originally Posted by TBRich View Post
Some people who, after have winterizing their rig, and end up using their rigs occasionally in the winter, leave the rig winterized and just don't use the bathroom facilities or the water systems....
You can have limited use the toilet in winter. Just keep a gallon of RV antifreeze handy and use it to flush toilet.
- - Mike
Boxster1971 is online now   Reply With Quote
Old 11-07-2013, 07:25 PM   #4
PSchw's Avatar
Livingston , Texas
Would the water freeze when you not use the heater? Is their a trick to prevent it from freezing between use?
Old 11-07-2013, 08:34 PM   #5
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
Turn the bypass valve to bypass and drain the water heater.
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 11-07-2013, 08:48 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you are camping and only use it a few times. If you keep the burner on. It won't freeze.
If you are storing the coach. Bypass and drain the unit.
Old 11-08-2013, 05:33 AM   #7
PSchw's Avatar
Livingston , Texas
Storage in my case would not be a problem as I have it inside.
So open the drain and drain the heater would be enough to keep it from freezing when I drive from one place to another.
I was thinking about leaving the heater on but if you drive the only way would be using gas which I am not sure if it would stay on with the frame. If I use the electric heater I have to run the generator when I am driving.
Old 11-08-2013, 06:02 AM   #8
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Unless it's insanely cold, it's not going to freeze while you're driving. I'd worry more about the pipes before the water heater.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 11-08-2013, 08:01 AM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you have used the water heater while camping. The water will be hot.
There would be no need to drain the unit while traveling.
It would take a long time to freeze 6-10 gallons of water.
You are right, it probably won't stay lit while driving.
Old 11-08-2013, 08:57 AM   #10
PSchw's Avatar
Livingston , Texas
I hoped the pipes and the tank would be ok as they are in the inside which would be heated.
I guess it's right having this large amount if water heated and have it close to a heated room should get me a few hours of travel and when I take a break I can run the gas heater and heat the water back up.
I hoped to find a generator driven by the engine to run the heater and I learned to difficulties about rpm changes and their impact on the generator which makes it not usable for all applications.
Thanks Peter
Old 11-08-2013, 09:12 AM   #11
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
I am not sure that the water heater would not remain lit while under way. It might be easier to verify that before you invest in a chassis generator.
Old 11-08-2013, 10:26 AM   #12
2005 22' Interstate
Pittsburgh , Pennsylvania
In my '05 Interstate, I run the water heater all the time while driving. I have never had a problem. It takes very little propane--certainly less than running the genset. Also, obviously, escaped heat from the water heater helps keep the adjacent pipes from freezing.
I have camped in extremely cold weather using the full water system. It is a challenge keeping everything working. The peripheral pipes are the biggest issue. I have occasionally resorted to a small electric space heater positioned in the far back where some pipes come too close to being "outside". it is kind of a fun challenge, actually.
avanti is offline   Reply With Quote
Old 11-08-2013, 01:49 PM   #13
PSchw's Avatar
Livingston , Texas
Thanks Avanti that is what I will try first. of course the simple solutions usually the last I am thinking off but some how I could not imagine the pilot light would stay one.
Old 11-08-2013, 02:01 PM   #14
73shark's Avatar
Not sure but I think it has electronic ignition instead of a pilot light.
