Old 03-25-2017, 11:28 AM   #1
The Woodlands , Texas
Water Heater Question
When I winterized my AI, I bypassed the water heater. Now that winter is over, can I leave it "bypassed" if I don't need hot water? Or, is it bad for the water heater to go unused?
Johnsrt is offline   Reply With Quote
Old 03-25-2017, 12:11 PM   #2
Muskogee , Oklahoma
Shouldn't hurt a thing.
gmillerok1 is offline   Reply With Quote
Old 03-25-2017, 12:51 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are going to leave the water heater unused for a prolonged period of time take a sealable plastic bag and put math balls in the ball. Seal it and then poke 20 or so holes in the bag with a pin and put in inside the outer cover. I would also drape a plastic bag over the face of the heater and colse the cover on it. This should keep spiders and other bugs from nesting in the burner tube.
I am assuming you drained the heater when you winterized. When you go to use it just crack the bypass valve while filling the heater. This will keep the sediment from being kicked up and you having to clean each faucet screen.
2004 Excursion 4x4
Old 03-25-2017, 03:29 PM   #4
2013 Interstate Coach
Waterloo , Iowa
There may be some merit in leaving it empty when unused. We had a rotten egg smell from the hot water heater after water sat in it a while. Old cold water never smelled bad. To overcome the smell I put a gallon of vinegar in the heater and let it sit on the bottom for a few days. This dissolved whatever nasty sediment was in there. I then drained and flushed.
Titus is offline   Reply With Quote
Propane Heater or Instant water heater valontjej Plumbing - Systems & Fixtures 1 04-09-2012 08:56 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
