Old 03-19-2016, 07:55 PM   #1
k9jackie's Avatar
2015 Interstate Ext. Coach
Great Falls , Virginia
Water heater question
Is there a reason why my water heater would not be working after dewinterizing? I did not connect city water, only used the tank to dewinterize. I'm hoping that's the reason and it is not broken...
Name:   ImageUploadedByAirstream Forums1458438922.103041.jpg
2014.5 Airstream Interstate Ext.
k9jackie is offline   Reply With Quote
Old 03-19-2016, 08:31 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by k9jackie View Post
Is there a reason why my water heater would not be working after dewinterizing? I did not connect city water, only used the tank to dewinterize. I'm hoping that's the reason and it is not broken...Attachment 259076
Have you looked at your fuses? There is also one located on the control board which is accessed thru the outer door. It's in the upper right hand side of the W/H.
No 12VDC control voltage to the board……no water heater!
Old 03-19-2016, 08:32 PM   #3
2011 Interstate Coach
Evansville , Indiana
You probably already checked these but the two things I would suggest are if you are on LP gas, make sure you have the LP solenoid switch turned on back behind the rear dual on passenger side. Also make sure the water heater bypass valve is turned off. It is a small yellow handle located under the rear lounge on the driver's side. Not the easiest thing to reach but if you have small hands you can get to it.
BurntAsphalt is offline   Reply With Quote
Old 03-19-2016, 09:19 PM   #4
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Simple things first:
What BurntAsphalt said above plus the following:
Fill tank with fresh water, then "prime" the hot water tank and lines by turning on the water pump and opening the faucets on the hot setting to ensure all the air is out of the pipes and tank.
Then test the water heater by either using the electric heater (electric water heater switch on); you will need to be plugged into shore power. Or test the gas water heater by using the gas heater switch. But I see from your photograph your propane level is showing red - empty or almost empty. So have it filled! And let us know.
Old 03-20-2016, 04:55 PM   #5
73shark's Avatar
Overland Park , Kansas
What the previous posters said plus generator power will also support the electric side of the water heater.
Old 03-21-2016, 02:40 AM   #6
k9jackie's Avatar
Turned the bypass on and all of my water flooded out of the water heater... I hadn't realized that they removed the plug when it was Winterized. 😕 I was able to fill up the tank again but still no hot water coming through. I will have to take it in to AS for list of things now. Good thing I have a back up shower at a friend's.
Old 03-21-2016, 03:54 AM   #7
Long Island , New York
Turned the bypass on and all of my water flooded out of the water heater... I hadn't realized that they removed the plug when it was Winterized. �� I was able to fill up the tank again but still no hot water coming through. I will have to take it in to AS for list of things now. Good thing I have a back up shower at a friend's.
So the water heater tank has been empty up up to this point? You might want to have the dealer go through all of the systems with you. Also recommend reading the owners manual thoroughly to avoid things like this in the future.
Old 03-21-2016, 05:13 AM   #8
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
On thing to be careful of is turning on the heater when it is not full of water. If you ever turn on the electrical heating element when there is no water in the tank (I.e.when it is winterized) the heating element will destroy itself.
I always throw the breaker when the trailer is winterized and tag it so I remember to turn it back on again!
Check your breakers...?
Bruce
Bruce B is offline   Reply With Quote
Old 03-21-2016, 05:36 AM   #9
Gainesville , Florida
No lp gas. Will it work on electric?
Old 03-30-2016, 08:49 PM   #10
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Bruce. Throwing breaker is Great idea! I barely use hot water so sometimes forget it's drained and bypassed! Post it note in cabinet might help too so I don't fire it up on gas!
Mike
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 03-31-2016, 04:08 AM   #11
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I turn off all the breakers every time I store the van, winterized or not. Just part of the "belt-and-suspenders" approach to ensuring I have only the minimum possible drain on the house batteries.
However, a post-it note stuck right to the control panel is an excellent idea as a reminder that the water heater is bypassed. Ever since I worked for the Corps of Engineers— and served on the Project Delivery Team to revise the last two editions of EM385-1-1, their Safety and Health Requirements Manual— I've been a big believer in lock-out/tag-out procedures. An RV has very few ways to lock out any electrical or propane system, and no good way to tag them out, either. Post-it notes next to the controls are the next best thing.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Propane Heater or Instant water heater valontjej Plumbing - Systems & Fixtures 1 04-09-2012 08:56 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
