Old 11-14-2014, 01:04 PM   #1
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
Water Heater Question
We finally used the water heater on our last trip out. WOW!! That's hot water. I know there is a mixing valve on the side of the water tank, to "extend" the apparent capacity of the tank. The supplied temperature on the datasheet for the heater is 130F...after mixing! Is the valve adjustable? Our home heater is set much lower (120F)...seems like I could extend my capacity a bit more if I set it back a bit. The back of the van is full of "stuff" right now or I would dig in there myself. Not trying to be lazy, I will get in there, just wanted to float a question first.
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 11-14-2014, 01:20 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I do not believe that the mixing valve is adjustable. I think it's fixed at a ratio of 2 parts hot to 1 part cold. If you were to take the temperature of the hot water before mixing, it would be closer to 165F.
But the faucets also serve as mixing valves, and I've always been able to set my faucets at something less than full hot in order to get the temperature down to a bearable level.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Protagonist is online now   Reply With Quote
Old 11-14-2014, 01:24 PM   #3
toskeysam's Avatar
Thanks Protagonist. Yes, the valves do provide mixing too... I just was having memories of a ship-board shower where I bounced off the walls (comedy show) until I could put the valve back in the position I really wanted.......do not want to repeat that again. Too many bruises on me and my ego.
FMCA # 436814
Old 11-14-2014, 02:41 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
The heater may be set high as a compromise with several factors coming into play.
Dish washing wants a high temperature. Code calls for 140 degree in commercial machines.
Hand washing is limited to 110 degrees in schools lest someone get burned. Which was interesting as I had to hold the temperature in the boiler room to 110 but had to have a boost heater in the cooking class room to jump it to 140, dishwasher and scrub sinks. So much for logic.
And probably the biggest single reason RV heaters are set where they are is the small size of the tank lest you run out of hot water while showering.
Yes 130 degrees is too hot if drawn by itself so use the faucet as the final mixer.
2004 Excursion 4x4
Old 11-14-2014, 06:39 PM   #5
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Our XO had shutoffs added at the shower head so once you had the temp set, you didn't have to waste water readjusting each time. Of course there was always water hours when one of the evaps was Tango Uniform. The boilers had first call on fresh water.
Old 11-14-2014, 07:09 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, you also have to consider the temperature of the incoming water; Some times, in cold weather, I have to turn my shower valve almost completely to the hot side. And in hot weather I have to turn my shower valve very close to the cold side.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Propane Heater or Instant water heater valontjej Plumbing - Systems & Fixtures 1 04-09-2012 08:56 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
