Old 09-24-2013, 08:18 PM   #1
Interstate1's Avatar
2014 Interstate Ext. Coach
Rochester , Michigan
Water heater drain cap question
What tool should I use to remove the drain cap from my water heater? It looks pretty tight to use a pair of pliers. Any suggestions?
Interstate1 is offline   Reply With Quote
Old 09-25-2013, 05:58 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Looks like a plastic plug with a hex head, if memory serves (haven't looked at mine since spring, so memory may not serve). If so, I'd try an open-end or box-end wrench. Shouldn't have to turn it very far at all to loosen it enough to turn with your fingers.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-25-2013, 06:19 AM   #3
2013 20' Flying Cloud
Cream Ridge , New Jersey
Not sure what water heater you have. Mine has a plastic plug with 1/2" male national pipe threads. It has a hex head that takes a 15/16" six point socket to get in there and remove it. Usually a twelve point socket will slip on a plastic hex head.
Joe Palmieri is offline   Reply With Quote
Old 09-25-2013, 06:22 AM   #4
norman , Oklahoma
I bought a socket to fit it (really wanted a 6 point but could not find one in the right size, so I settled for a 12 point socket). I could only find one in a 1/2 drive so I also bought a 1/2 to 3/8 and a 3/8 to 1/4 adaptors so I could use a 6" long 1/4 drive extension on my 1/4 drive ratchet handle. With that rig I can slide it all up through the heat shielding and turn it easily. My Interstate is in the shop right now (replacing the rear view camera is a huge pain in the butt BTW, my mechanic has the interior half torn out out it pulling the wire from the front to the back) but as soon as I get it back I can tell you what size the socket is. I guessed and bought 3 different sizes and then returned the two that were not it (I drove the AI to Lowes so facilitate). While I was there I also got a socket to fit the fresh water drain.
russ240 is offline   Reply With Quote
Old 09-25-2013, 06:24 AM   #5
dznf0g's Avatar
Oswego , Illinois
Crows foot wrench was needed for mine. Gas line runs right in front of it.
-Rich-
Old 09-25-2013, 06:34 AM   #6
norman , Oklahoma
Joe is right, the 12 point is not optimal, but it beat the heck out of the adjustable wrench I was using! I'll try and confirm that mine is the same size he mentioned (15/16") this afternoon.
Note: The third or fourth time I had the plug out, it was leaking a couple of days after i put it back in. When I put my socket on there to snug it up to try and stop the leak, I snapped the head off the plug (too tight I guess, or it was fatigued/brittle?)! Luckily the water was not at full temp or I would have been scalded. Once I got the stub of the plug out of the tank drain, I switched to a brass plug (that was all I could find at the hardware store that would fit). Since then I ordered replacement plastic plugs through my dealer, but I have not removed the brass one to switch back yet. I like the idea of the plastic plug so the plugs threads will be sacrificial to the expensive and hard to replace water heater, but the brass one sure seals up nice! I will replace the plastic plug periodically from now on to try and prevent future failures and will be sure to always release the pressure before messing with the plug (and service the unit with the water cool!) to prevent injury in the event it does fail! I always turn the water pump off and turn on the hot water in the sink to let the pressure off before I pull the plug but did not think to do that before snugging it up ... could have been a painful mistake! I got lucky.
Old 09-25-2013, 06:47 AM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I try to use a new plastic plug whenever I pull it out, keep some spares on hand, or they tend to leak.
I've seen the brass plugs but wonder if this would set up a corrosive situation because of the dissimilar metal aluminum tank.
Doug and Cheryl
Old 09-25-2013, 07:08 AM   #8
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Don't you love the engineer that figured that out DAAAA!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 09-25-2013, 07:33 AM   #9
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
Most RV shops including Camping World sell replacement drain valves made of brass to replace the plastic plug; $7 or less. I've even seen one that allowed for the installation of a short piece of plastic tubing so the water flows outside of the water heater cavity rather than having it drool all over itself.
Now that I think about this, I'm going to look into using a short section of braided SS water supply hose and a 1/4 turn stop.
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 09-25-2013, 08:16 AM   #10
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
CW had this one....
ID:	196355   Click image for larger version
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 09-25-2013, 08:37 AM   #11
mandolindave's Avatar
Not suitable for my regime but....
My friend put a valve on the his water heater drain. I decided not to, because I like to syphon as much water out as possible when winterizing. The valve would impede that process.
mandolindave is offline   Reply With Quote
Old 09-25-2013, 08:53 AM   #12
Kevin245's Avatar
We changed to a compact ball valve a few years ago.
Here is a link to our old post. Atwood water heater drain plug - Airstream Forums
Eleanor Roosevelt
Old 09-25-2013, 02:53 PM   #13
dznf0g's Avatar
Oswego , Illinois
I recently found out that opening the low point drains on mine, and driving home from the CG gets more water out of the water heater than any other method!
-Rich-
Old 09-25-2013, 03:24 PM   #14
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
I came across this idea recently...... I think I'll give it a try this year when winterizing.
Landrum is offline   Reply With Quote
