Old 11-07-2015, 06:31 AM   #15
On a related note, here is a venting mistake that I made only once:
Flush the commode with the wet bath door shut and the bath fan running. The Interstate is so tight that the bath fan will draw air directly from the black tank via its vent, rather than through the bath door seam. Very, very undesirable result. Kitchen venting questions kinda pale in comparison.
Old 11-07-2015, 09:11 AM   #16
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Not a problem on the new ones since the movable wall is open at the bottom. This allows the exhaust fan to draw air from the main compartment.
Old 11-08-2015, 10:10 PM   #17
2015 Interstate Ext. Coach
Chicago , Illinois
Thanks everyone. All very helpful, as usual.
Marks71 is offline   Reply With Quote
Old 11-09-2015, 08:50 AM   #18
Trying to Retire
MILATV's Avatar
Decatur , Illinois
My 2014 doesn't have tip-out behind stove either (only in far back L/R + Sliding Door).
I open the curb side front door window a 1/2 inch or so and run fan while cooking (so I don't pull cold air over the bed - wife doesn't enjoy that much).
Just have to watch your windows and external exhaust if setting still and running vehicle or generator. I don't open Curb side if engine running, don't open driver side if generator running.
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Venting! ArtStream Roof Vents, Skylights & Fans 16 03-31-2009 11:34 AM
Propane tanks venting! Resorts LP Gas, Piping, Tanks & Regulators 20 06-22-2007 06:36 AM
Replacing cooktop with oven - venting issues??? Alumatube Stoves, Ovens & Microwaves 2 03-30-2007 07:10 AM
1960 fridge venting Safari Tim Refrigerators 19 01-30-2007 09:24 PM
Refer heat / venting JaceBeck 1999 Safari 3 08-21-2003 08:40 PM
