Old 02-28-2016, 07:53 PM   #1
2015 Interstate Coach
MEDFORD , New Jersey
valve stems extender for tire pressure
Can anyone recommend a valve stem extender for my AS. impossible to check the tire pressure on rear tires.
RICKBETTY is offline   Reply With Quote
Old 02-28-2016, 08:33 PM   #2
2011 Interstate Coach
Muskogee , Oklahoma
http://yourtireshopsupply.com/produc...-chrome-dl1spc
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 02-28-2016, 08:43 PM   #3
73shark's Avatar
Overland Park , Kansas
Here's the one I got: http://www.yourtireshopsupply.com/pr...yvalve-dl1spal
Not sure what the difference is except the curvature on the outer dual stem.
Full disclosure: Never got around to installing them. Decided to let the next owner install if he wants to.
To check the rear pressure, you'll need a dual head gauge like this:
Old 02-28-2016, 08:55 PM   #4
Muskogee , Oklahoma
That is correct for the Alcoa wheels. I cut and pasted too quickly. There is no need for a special air chuck. I have the exact same you posted on mine.
Old 02-28-2016, 09:13 PM   #5
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
GMiller and Shark are right on. The Dually Valves are the way to go.
c21bill is offline   Reply With Quote
Old 02-29-2016, 10:01 AM   #6
Dalwyn's Avatar
2015 Interstate Grand Tour
Southaven , Mississippi
Last year on my Interstate, I fought the air hose, the gauge, tires and everything else it seemed like when I tried to check the air or put air in the rear duallies. This year I got smart and had the DuallyValve DL1SPAL installed. They work great.
Dalwyn is offline   Reply With Quote
Old 02-29-2016, 10:07 AM   #7
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
+1 on the Dually valves mentioned above. I have them also, with a TST TPMS that works great.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 02-29-2016, 10:23 AM   #8
- - Mike
Ditto on the TST TPMS. Very easy system to install and use. User replaceable batteries are a big plus with this system.
Old 02-29-2016, 11:02 AM   #9
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
I just installed these and like em.
mayco is offline   Reply With Quote
Old 02-29-2016, 11:51 AM   #10
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I had problems with flexible extensions on my Interstate. Couldn't make the extensions for the inside duals stop leaking, possibly because the inside duals have rubber stems and the flexible extensions were too heavy for them.
I went with rigid aluminum extensions, straight for the inside duals, "J" shaped for the outside duals, and they don't leak.
http://www.amazon.com/Wheel-Masters-...tem+extensions
I did use a 3' flexible extension on my spare, with the outer end attached to the rear bumper, so I could check and reinflate my spare without crawling underneath, and it works without leaking.
http://www.amazon.com/Wheel-Masters-.../dp/B002IUCFIA
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-29-2016, 02:13 PM   #11
73shark's Avatar
FWIW, Wheel Masters states they are nickel plated brass. Thought they were pretty shiny for aluminum altho I realize polished aluminum can be shiny, just doesn't stay that way long. See Alcoa wheels on our AIs prior to Durabright.
Old 02-29-2016, 04:33 PM   #12
What can I say? Senior moment. Thanks for the correction. In any event, they work for me.
WBCCI #1105
TAC LA-4
Old 02-29-2016, 05:08 PM   #13
Raymond , Iowa
The plastic extenders that came on the inner dual were worthless - wasn't able to add air through them. I feared too much spinning mass if I used metal extenders on the rubber stem. So I unscrew the cap on the rubber stem and screw on the metal extender each time I want to check/add air. Not real handy, but didn't want to pay for metal stems until I had the wheels off for other reason (such as new tires).
Titus is offline   Reply With Quote
Old 02-29-2016, 05:10 PM   #14
Fulton , Maryland
Originally Posted by Protagonist View Post
I had problems with flexible extensions on my Interstate. Couldn't make the extensions for the inside duals stop leaking, possibly because the inside duals have rubber stems and the flexible extensions were too heavy for them. ....
Those rubber valve stems on the inner dual wheels are a real problem if you attach anything besides the lightweight plastic extensions installed by Mercedes. I attached a set of flow thru caps on mine and I'm sure they caused the flat I had.
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
Dill TPMS Tire pressure monitor valve stems TexasToaster Tires 15 11-19-2015 12:11 PM
Dually Air Valve Extender Glamper1 Sprinter and B-van Forum 28 05-09-2015 11:42 AM
Tire Valve Stems Airperson Tires 11 04-30-2011 06:22 AM
New Tire Problem Chinese valve stems HowieE Tires 23 09-05-2008 11:20 AM
