Old 03-08-2015, 02:59 PM   #1
k9jackie's Avatar
2015 Interstate Ext. Coach
Great Falls , Virginia
Using the TV in a 2014.5
Should I be able to use the televisions on battery power or while I am driving? I'm having trouble turning them on but my batteries are 100%. I don't have electricity hookup at my house and I don't want to turn on the generator just to try the TV (noise might upset my neighbors) I didn't video the TV demo and I am feeling like an idiot! Help 😁
2014.5 Airstream Interstate Ext.
k9jackie is offline   Reply With Quote
Old 03-08-2015, 03:13 PM   #2
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
When the coach batteries are enabled with the switch by the door, you can toggle on and off the inverter from the on button on the Magnum control in the overhead locker. When the inverter is on, a small green light will come on. Then you can use the TVs. Don't leave the inverter on when not required since it uses the coach batteries.
Old 03-08-2015, 03:46 PM   #3
k9jackie's Avatar
ok, thanks. I didn't realize the inverter had to be on.
Old 03-08-2015, 04:35 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The antenna amplifier in the compartment over the driver's seat needs to be on as well, unless you're playing DVDs. As with the inverter, don't leave the amplifier on when you're not using it.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-08-2015, 05:39 PM   #5
k9jackie's Avatar
I guess I missed the amplifier demo. I'm going to check it out now and see if I can find it! thanks for your help.
Old 03-08-2015, 05:43 PM   #6
Ron_CA's Avatar
San Diego , California
You also will need to run the auto program feature to get the most channels if you are not hooking up to cable. Do this every time you are at a new location.
Ron_CA is offline   Reply With Quote
Old 03-08-2015, 05:59 PM   #7
2015 28' International
Aloha , Oregon
Inverter on *and* you need to plug your TV into the Blue marked plugs that are connected to inverter.
Your TV might by default be plugged into the standard (shore power) 120V outlets.
garybair is offline   Reply With Quote
Old 03-08-2015, 06:00 PM   #8
Aloha , Oregon
..that is, if an interstate has outlets like the newer trailers do. I have no idea on that..
Old 03-08-2015, 06:32 PM   #9
Nope. No blue outlets. The televisions are plugged into dedicated inverter-powered outlets, though, and the televisions can be used while the vehicle is in motion.
WBCCI #1105
TAC LA-4
Old 03-08-2015, 07:13 PM   #10
k9jackie's Avatar
I couldn't find the on/off button for the antenna... Anyone have photos of it?
Old 03-08-2015, 07:29 PM   #11
UKDUDE's Avatar
Sedona , Arizona
Open the left hand sliding cabinet door on the cabinet above the driver's seat, and peer inside with a flashlight on the wall on the left. You should see wires and antenna cables and a white box with a button on it. Press the button, and with the coach batteries enabled, a green light will come on. This is only for the antenna amplifier and not for use when cable TV is connected.
Old 03-08-2015, 07:30 PM   #12
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
It's in the locker over the driver's head. It's a little push button that sticks out. It is on when it's pushed in and a LED will lite. It will be off when the house batteries are off even w/ the switch in the On position.
Edit: Beat me by just a little bit.
Old 03-08-2015, 07:31 PM   #13
UKDUDE's Avatar
Sedona , Arizona
Also, when you run the setup function on each TV, make sure it is set to "Air" and not "Cable".
Old 03-08-2015, 09:36 PM   #14
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Jackie - the TV booster is in overhead cabinet above driver's head. It's mounted on the outside wall inside this cabinet and looks like attached page from owners manual.
- - Mike
NorCal : 2014 Jackson Rancheria Rally, October 10-12, 2014 Coastalview Forum Rallies & Meet Ups 240 01-03-2015 02:04 PM
won't start using the key/no power at all 72prostreet Electrical - Systems, Generators, Batteries & Solar 15 02-23-2010 05:53 PM
Instructions on using Velcro to attach homemade curtains tiniree Upholstery, Blinds, Walls & Interior Finishes 3 04-30-2003 10:49 PM
tow hitch height using a 1960s car oldvws Hitches, Couplers & Balls 15 11-27-2002 03:43 PM
Gubernatorial Candiate using an Airstream Chuck Airstream Motorhome Forums 4 08-12-2002 04:07 PM
