03-12-2019, 06:01 PM
2020 30' Classic
Richmond
, Virginia
Using 12v Air compressor
Sorry if this is a dumb question but I haven’t been able to find an answer. I would like to order a Viair 12v aid compressor. Can I use the “jumper terminals” under the hood to power the compressor? Crawl under and use the house batteries? Curious how you power it.
Thanks!
03-12-2019, 06:07 PM
2017 16' Sport
N/A
, N/A
The only dumb question is the one that’s not asked. Yes, you would use the battery under the hood of your TV Viair recommends operating the engine of the TV. That’s how I use mine.
03-12-2019, 06:10 PM
2020 30' Classic
Richmond
, Virginia
I should have clarified, I’m on a 2017 sprinter 3500 and so I don’t have direct battery access, I have the “jumper port” (under the red knob). Is that okay to use?
03-12-2019, 06:12 PM
Sag Harbor
, New York
Thanks!
Yes the jumper terminals under the hood should have sufficiently large cables to the remote battery, to support this use IMO. We recently used our Viair 450 in this manner, with our TV van with remote batteries.
Peter
03-12-2019, 06:13 PM
Sag Harbor
, New York
The OP sets forth different details IMO.
03-12-2019, 06:21 PM
Sag Harbor
, New York
Peter
To clarify and correct, it would actually be only the positive terminal with a large cable to the remote battery in our van IMO. The negative connection is via a nearby large bolt on the engine compartment metalwork.
Your AI terminals might be different? Whatever your manual instructs for jump starting should work for the Viair IMO.
03-12-2019, 06:33 PM
2014 Interstate Coach
Arroyo Grande & Central Point
, California & Oregon
Thanks!
I have a Viair and I use the jumper posts to power mine.
03-12-2019, 06:38 PM
2013 Interstate Coach
Waterloo
, Iowa
My 2012 Sprinter came with a 12V compressor in the compartment accessible when the passenger door is open. It plugs into the cigarette lighter socket. I have run it for appx 5 minutes without blowing a fuse.
03-12-2019, 06:42 PM
Sag Harbor
, New York
The Viair compressors draw too much wattage to use that method.
03-12-2019, 07:03 PM
2010 25' FB Flying Cloud
Davenport
, Iowa
Viair has a model 85P that is 12 volt lighter connection. Does not have much power or run recovery time. I have the 88 P and like,it. Get the extension hose. Mine does not reach from battery to right rear tire.
Mike
03-12-2019, 08:18 PM
Sag Harbor
, New York
Thanks Mike for that correction.
Peter
03-13-2019, 09:30 AM
St Petersburg
Using a Viair on a Sprinter
I have a 2016 Interstate and regularly use my Viair 12 V compressor from the jumper lugs in the engine compartment. Be sure to have the engine running, as the Viair is a big amp draw that needs engine support.
Electrically speaking, the jumper lugs are at the same electrical potential as the battery lugs.
OK...be well and good luck.
Pirate Chris
Thanks!
03-13-2019, 11:26 AM
Stay CazuaL
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda
Thanks!
Short Answer: Yes.
Recommend you have the car running.
Secondly, I use this to make it easier for me.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
03-13-2019, 12:01 PM
Sag Harbor
, New York
That accessory will not work with the larger capacity Viair compressors, like our 450, because the AWG #16 wire is too small. Also our 450 has the alligator clips like a jumper cable to attach directly to a battery (or remote terminals like the OP). [See earlier posts]
Peter
03-14-2019, 12:46 PM
2019 Interstate Lounge Ext
Lakewood Ranch
I have and use the Viair 88P and connect to the terminals under the hood with no issues.
03-14-2019, 02:39 PM
Contributing Member
Austin (Hays County)
I installed a marine trolling motor socket in the rear of the AI with #12 wires to the batteries and put a trolling motor plug on my air compressor. I fused the lead to the compressor.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
03-14-2019, 02:50 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by cazual6
The 'car running' thing...I just pulled the 'Burb out today getting ready for the coming Season. All tires were at 25psi & off the ground.
I just connected our new 450P RV and filled all tires to 70psi., Took the Vair 15min of running time.
The battery,(Interstate Plus), was still at 12.6v w/o the engine running. Very impressed with this unit.
Peter
Peter it was your purchase that led me to the 450, Thanks.
03-14-2019, 03:51 PM
2017 16' Sport
N/A
, N/A
XX for Viair 450P RV I am very happy with its performance I have these photos in my photo library to refer to.
03-15-2019, 12:34 AM
Sag Harbor
, New York
Thanks. Funny, that was a while ago, and I only tested the thing in the last week or two, getting ready to go camping.
What a great carry case and nicely made unit. I am going to order a longer air hose and a small regulator set-up.
Peter
03-15-2019, 03:09 AM
Sag Harbor
, New York
PS -- So that this thread does not turn into a Viair 450 discussion, there are plenty of other AF mentions:
https://www.google.com/search?q=Viai...com&gws_rd=ssl
Happy trails!
Peter
