Old 03-14-2019, 12:46 PM   #15
Brezzin's Avatar
2019 Interstate Lounge Ext
Lakewood Ranch , Florida
I have and use the Viair 88P and connect to the terminals under the hood with no issues.
Brezzin is offline   Reply With Quote
Old 03-14-2019, 02:39 PM   #16
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
I installed a marine trolling motor socket in the rear of the AI with #12 wires to the batteries and put a trolling motor plug on my air compressor. I fused the lead to the compressor.
John W. Irwin
WBCCI #9632
Old 03-14-2019, 02:50 PM   #17
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by cazual6 View Post
Short Answer: Yes.
Recommend you have the car running.
Secondly, I use this to make it easier for me.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
The 'car running' thing...I just pulled the 'Burb out today getting ready for the coming Season. All tires were at 25psi & off the ground.
I just connected our new 450P RV and filled all tires to 70psi., Took the Vair 15min of running time.
The battery,(Interstate Plus), was still at 12.6v w/o the engine running. Very impressed with this unit.
Originally Posted by OTRA15 View Post
That accessory will not work with the larger capacity Viair compressors, like our 450, because the AWG #16 wire is too small. Also our 450 has the alligator clips like a jumper cable to attach directly to a battery (or remote terminals like the OP). [See earlier posts]
Peter
Peter it was your purchase that led me to the 450, Thanks.
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 03-14-2019, 03:51 PM   #18
Silvr_Bullet's Avatar
2017 16' Sport
NA , New York
XX for Viair 450P RV I am very happy with its performance I have these photos in my photo library to refer to.
ID:	335696   Click image for larger version
Silvr_Bullet is offline   Reply With Quote
Old 03-15-2019, 12:34 AM   #19
Long Island , New York
Thanks. Funny, that was a while ago, and I only tested the thing in the last week or two, getting ready to go camping.
What a great carry case and nicely made unit. I am going to order a longer air hose and a small regulator set-up.
Peter
OTRA15 is online now   Reply With Quote
Old 03-15-2019, 03:09 AM   #20
PS -- So that this thread does not turn into a Viair 450 discussion, there are plenty of other AF mentions:
https://www.google.com/search?q=Viai...com&gws_rd=ssl
Happy trails!
Peter
Old 03-15-2019, 05:48 AM   #21
Peter
I'm slow to react...we always carried a B&D AC portable that worked pretty well, but having to start the Honda several times last Season was a bit of a PITA. 12lbs of Vair is a lot easier than 56 of Honda.
Got the 450P RV from Amazon...open box return saved $70.
It did come with the screw on valve hose a second coiled extension, and a nice pistol grip handle with gauge that shuts off the pump when the trigger is released...nice feature that helps keep the compressor from from overheating.👍
I won't say much more...I've only filled 4 tires so far.🥴
Amanamus
"Tahawus"
12v
Viair 88p 12v air compressor. Caffeinated Tires 5 07-14-2016 09:06 AM
Wet sanding using a AIr Compressor? MegHighway1 Cleaning, Stripping & Polishing 7 11-02-2013 11:58 AM
Good Cheap 12V Air Compressor Suggestions perryg114 Tires 30 01-16-2013 09:55 AM
No air coming through faucets with winterizing/using compressor MStewart Winterizing, Storage, Carports & Covers 21 10-26-2011 09:34 AM
Review - 12V Central Penumatic air compressor cammur Tires 5 11-17-2007 02:15 PM
