Old 10-30-2015, 05:54 PM   #15
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
I notice that Magnum has two similar remotes, the ME-RC and the ME-ARC. What is the advantage with the ARC? The main thing I wish to accomplish is to match the Magnum to the battery capacity which is now 220AH.
Thanx,
Bill
c21bill is offline   Reply With Quote
Old 10-30-2015, 09:18 PM   #16
lewster's Avatar
Naples, FL , Hood River, OR
No need for the ARC unless you are a total techie and like to continually look at data that the ARC provides. In all of the Magnum installations I gave done over the last 10 years, I have only used 2 ARCs vs. the RC remotes.
Both have the same programming parameters for battery charging. Both are much better than the ME-MR that Airstream provides.
Save the bucks and use the ME-RC.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 10-30-2015, 09:28 PM   #17
I spent too long typing my reply.
edited to: What Lew said.
LB_3 is offline   Reply With Quote
Old 10-31-2015, 11:05 AM   #18
Thanks Lew.
Lew Farber
541-490-6357
Old 10-31-2015, 12:58 PM   #19
Lew da man!
Old 10-31-2015, 07:21 PM   #20
Lew, I ordered a ME-RC, could you give me the parameters to use? I know to set the capacity at 220 but what should I use for the others?
Bill
Lew Farber
541-490-6357
Old 11-02-2015, 01:18 PM   #21
lewster's Avatar
Here are the ME-RC settings I use for a 220 A/H Lifeline bank:
Search watts: 5
LBCO: 11.5
Absorb time: 1.5
Battery type: AGM-1
Charge Rate: 100%
VAC dropout: 100
Power save: 1 min
Screen setup: 100%/100%
Final charge: Multi
Power up always: No
Lew Farber
541-490-6357
Old 11-02-2015, 01:43 PM   #22
Once again Lew, thank you for sharing your knowledge!
Bill
Old 11-03-2015, 01:47 PM   #23
2014 Interstate Ext. Coach
Antrim , New Hampshire
Search watts: 5
LBCO: 11.5
Absorb time: 1.5
Battery type: AGM-1
Charge Rate: 100%
VAC dropout: 100
Power save: 1 min
Final charge: Multi
Power up always: No
Lew Farber
541-490-6357
.........ahhh thank you, that's good news. So my ME-MR will be good for a while.
AH set for 400 instead of 200, which gives me 90 minutes absorb, helps greatly. The only other question; Lifeline gives 7.10 to 7.30 absorption charge voltage for the GPL-4CT. This would make it 14.2 to 14.6 volts in series. Theoretically then the battery type could be set to AGM-2, which I did. Would I miss something by doing that?
felixkagi is offline   Reply With Quote
Old 11-03-2015, 02:59 PM   #24
Montrose , Pennsylvania
Is it supposed to be on the negative or positive terminal?
bsedor is offline   Reply With Quote
Old 11-03-2015, 03:05 PM   #25
Never mind, I just saw the other post!
Thanks! Lew!
Old 11-03-2015, 04:23 PM   #26
lewster's Avatar
The voltage should be 14.2-14.4 for 12 VDC systems, which you have. The Magnum usually splits the difference to 14.3VDC. I would leave it on AGM-1.
Lew Farber
541-490-6357
Old 04-14-2016, 07:44 AM   #27
mdf
2016 Interstate Lounge Ext
Belvedere , California
Originally Posted by Dalwyn View Post
I just had my coach batteries upgraded to Lifeline GPL-6CT for my 2015 Interstate Grand Tour. Did have to have new cages built and that was expensive, but hopefully I will have enough power now to get me through the night running the fridge and freezer.
I do have a question. I want to make sure that I don't ruin these so is it okay to leave coach plugged in all the time when the unit is in the garage or should I disconnect? Still has the standard Magnum inverter.
Dalwyn -- any more info you can share on the "custom" battery cages? Assume you mounted in the same location as the stock batteries under the coach? I'm interested because I want to do this same upgrade for my soon to be delivered 2016. Thank you!
mdf is offline   Reply With Quote
Old 08-30-2017, 10:59 AM   #28
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
Search watts: 5
LBCO: 11.5
Absorb time: 1.5
Battery type: AGM-1
Charge Rate: 100%
VAC dropout: 100
Power save: 1 min
Final charge: Multi
Power up always: No
Lew Farber
541-490-6357
Thanks for the wealth of information which I used to upgrade my batteries to 200A/H lithium.
Could you give me a the set up for the ME-RC for 200A/H Lithium. The batteries are Battle Born Batteries 2 x Group 27 each with 100A/H with build in management system.
I also just burned the ground out of my MMS1012 and are wondering if this could anything to do with the new batteries or did Airstream just do a bad install (loose wire) when they upgrade me from a Tripp-Lite.
Due the Lithium need the BTS?
You help is greatly appreciated.
peter
PSchw is offline   Reply With Quote
Upgraded converter, now not charge batteries? Sphere Guy 2008 Safari SE 10 06-05-2014 08:22 PM
Upgraded and found a glitch on P-3 lewster Brakes & Brake Controllers 14 12-07-2008 12:54 PM
Just upgraded to a 2005 Safari 25 ss !! DEO 2005 Safari 25 05-28-2004 09:04 PM
