Old 11-28-2015, 02:28 PM   #1
Rockwell , North Carolina
Updating to Larger TV in 2013 Interstate
About a month ago my son and I traveled to Greenville, SC to a car show. A local Airstream dealer had a new Interstate on display. The first thing I noticed was the larger front TV. My wife and I occasionally watch movies and the standard 18" is pretty small to view from the rear seat. So I decided to upgrade to the new 28" Samsung TV. I found the same model that Airstream is using on eBay. Below you can see the difference in size.
Not wanting to reinvent the wheel, I decided to purchase the mounting kit from Airstream. We were planning on traveling to northern Indiana from our NC home for Thanksgiving so I called them to order the kit and pick it up at the factory on our way to Indiana. I pre-paid for the kit and expected to be there no longer than 10 minutes to pick it up. We ended up being there an hour because they had the wrong part number in their system for the plate that mounts to the TV. They were very nice about it but it was disappointing to have to waste that much time.
The kit consists of the wood part with hinges and catches that attaches to the front storage area, the steel plate that attaches to the TV and the studs and wing nuts for attaching the plate to the TV.
I removed the original TV and cleaned up the wiring in anticipation of installing the new TV. Since this TV does not have a built-in DVD player, I bought a Blue Ray player at Wal-Mart and, using Velcro, I installed it on top of my Dish receiver.
Airstream's TV vendor modifies the TV's to allow the use of headphones by adding some additional wiring. You can see that wiring below on the old TV. Since we are using Bluetooth headphones and never use the standard headphone jacks, I discarded this wiring.
I laid everything out on my bed to mount the plate to the TV. Once it was mounted I mounted the catches to the plate. Initially I mounted them both in the same direction but soon discovered that they were mounted in opposite directions to allow the TV to latch to the base mount.
The hinges have slots in them. After starting the nut on each of the studs, I placed the hinges on the plate and tightened the nuts just enough so I could slide the TV out of the slots.
In making this upgrade, I had decided to remove the sliding plastic doors on the front storage area. With the new TV being larger, little of that area in seen and this allowed me to run the cables to the through the back of the mount. To make that work I had to drill a 1" hole in the center of the mount. Since I wanted both of us to be able to see the entire screen from the rear sofa, I offset the TV towards the left side and mounted the base,
The four screw holes from the original mount were visible. To make them less visible, I simply inserted the original screws.
Now I was ready to mount the TV to the base mount. The nice thing about the new mount is that you can tip the TV out at the bottom for access to the rear.
With the TV mounted, I was ready to wire it up. Through the 1" hole I ran the TV power cord, the HDMI cables from the Dish receiver and the DVD player, and the headphone jack that is connected to the radio to hear the TV over the radio speakers. There are two studs on the mounting plate to use as places to secure the wiring. I had to extend the RG6 antenna cable to make it work. The wires have to be run to the top stud and then down to the bottom stud so the wiring runs along the bottom of the TV. This keeps them out of the way when you latch the TV to the base mount.
With the wires run, it was time to make sure everything worked. It did and and I am sure we will be very happy when we use this TV on our planned trip to Florida in January.
jerhofer is offline   Reply With Quote
Old 11-28-2015, 05:18 PM   #2
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
How much did Airstream charge for the mount. Also will the TV drop down with the new mount or is it at a fixed height/
c21bill is offline   Reply With Quote
Old 11-28-2015, 07:18 PM   #3
They charge $300, which is outrageous. But, it sure made the installation easy.
The TV does not drop down. It only swings out from the bottom. As I mentioned earlier, that makes it easier to get to the connections. I assume the other reason was for ease of assembly on the production line. My only concern is that it will be a head knocker. I am considering installing some type of padding on the bottom of the TV.
Old 11-29-2015, 05:04 PM   #4
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Isn't the swing-out function a storage position to minimize the head bump scenario?
Old 11-29-2015, 07:26 PM   #5
If you look at the photo above where it is swung out, you can see that it is still lower than the front overhead storage area. I found it to be in the way when it was swung out and bumped my head a couple times when I forgot it was there while doing the wiring. I am sure we will get used to its position.
Old 11-29-2015, 08:09 PM   #6
73shark's Avatar
Didn't realize that it didn't go up to the horizontal position. So now not sure what the purpose of the mount is other than making it a lot easier to wire up.
Old 11-29-2015, 09:15 PM   #7
2016 Interstate Lounge Ext
Heathrow , Florida
The most frequently uttered phrase in my AI is "WATCH YOUR HEAD!" My wife and I average two to three head injuries per trip. Need to either travel wearing a helmet or add foam to the bottom of the tv.
Harleydeal is offline   Reply With Quote
Old 11-29-2015, 09:19 PM   #8
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I never bump my head on the bottom of the front television. But at least twice a year I bump my head on an open overhead locker door— if I hit a corner rather than an edge it usually draws blood. No hair to pad my scalp, you know!
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-02-2015, 04:27 PM   #9
At Lowe's I found some foam insulation for plumbing pipes that was slit and had the adhesive already in place. I cut a straight piece for the bottom and made a corner piece for the right side. Not too worried about hitting the corner on the left side of the TV. I had to cut out a hole for the remote control sensor at the bottom right of the TV. We'll see how well the adhesive holds up.
Old 12-04-2015, 07:28 AM   #10
I'm fine with my front tv's size and location and I really like the built-in DVD player. What I would really like is to find a mount that would allow the tv to drop down into a better viewing position. Any tested ideas on this would be greatly appreciated.
Bill
Old 12-04-2015, 09:04 AM   #11
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Drop down front TV mount
Bill
Bill,
I installed a drop down TV mount last year. I searched for a TV mount and this is the one I ended up using:
Amazon.com: VonHaus Cantilever LCD Monitor TV Arm Bracket Wall Mount with Swivel and Tilt - Fits most 13" - 24" LCD Flat Panels: Electronics
Then I had to find some thing to lock in the up and stowed position. I used two of these latches:
http://www.amazon.com/gp/product/B00...ilpage_o00_s00
I also had to open up the side panel where wires run to TV to add a longer power cord. The whole job got pretty complicated. I also had to glue one of the swing joints to lock it from giving me too many hinged joints. It may be possible to find a better approach, but this one has worked well for us over the last few years and about 40,000 miles of use. I've posted photos in the past but here are some photos of the details.
Enjoy,
- - Mike
ID:	253295   Click image for larger version
ID:	253297   Click image for larger version
ID:	253299   Click image for larger version
Old 12-23-2015, 10:58 PM   #12
Originally Posted by Boxster1971 View Post
Bill,
GN 417 Series Zinc Die Cast Latch Mechanism Indexing Plunger with Pull Ring, 20.5mm Length, 4mm Diameter: Metalworking Workholding: Amazon.com: Industrial & Scientific
Enjoy,
- - Mike
Hi Mike, I located a different, compact mount that has a built in travel lock and looks like it will do the job. I have that on order. From your post I glean that all the wiring is long enough except the power cord. I have scoured the internet in an attempt to find a short extension with the C7 Female to Male Polarized connectors to no avail. How did you gain access to replace the cord with a longer one?
Bill
Old 12-24-2015, 12:57 AM   #13
Bill
I faced a similar dilemma as the cord plug on the new TV was different than the one on the standard TV. I could not see an easy way to remove the standard cord. In my case, since I eliminated the sliding panels, I left the original cord in place and then ran the new cord from the receptacle directly to the TV.
My alternative solution would work for you. Simply cut the cord and splice in whatever additional cord you need to make it work. If you are installing a TV with a different end, cut off the end on the existing cord, cut off whatever length you need from the new cord and splice them together.
Old 12-24-2015, 08:43 AM   #14
Fulton , Maryland
Bill
I got lucky. I had a longer power cord in my "collection" of old stuff I save when various electronic items die. 😄
I pulled the side panel above the driver seat to get full access to the wires running to TV. Have a closer look at the last two photos I posted above. They show the wire runs.
Merry Christmas!
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Ideas for larger-scale meal transport in an Interstate? InterBlog Sprinter and B-van Forum 79 08-23-2017 04:22 AM
Interstate :: 2013 Airstream Interstate AtlantaCpl Airstream Registry Discussions 1 09-07-2013 07:12 AM
Mercedes Interstate 22' 3500 :: 2013 Airstream Interstate Suru Airstream Registry Discussions 0 05-05-2013 09:23 AM
Updating Electrical Goodies... JeepinAudiophile Electrical - Systems, Generators, Batteries & Solar 43 03-04-2005 05:27 PM
First Big job.updating toilet from chemi to real rheadhuntress Sinks, Showers & Toilets 2 04-19-2004 06:08 PM
