Old 05-03-2019, 11:43 AM   #1
GoingPhishin's Avatar
2017 Interstate Grand Tour Ext
Castle Rock , Colorado
Under Carriage Lights Won't Turn On
I can't get the under carriage lights to turn on. I have power to the switch, so it is not the little battery behind the switch that needs to be replaced. I can get the awning out and the lights on the awning to work, so I do not think it is a fuse issue (I assume they are on the same fuse).
Any other ideas?
Thanks!
GoingPhishin is offline   Reply With Quote
Old 05-03-2019, 02:18 PM   #2
2017 Interstate Lounge Ext
Jacksonville , Jacksonville, Fla, Sautee, Ga, Boca Grande, Fl, Breckenridge, Co
Suggest you replace the battery, I did when I had the same issue and that was the solution.
busb2 is offline   Reply With Quote
Old 05-03-2019, 03:04 PM   #3
Just to be clear, you are talking about the little round battery (watch battery type) behind the light switch?
Old 05-03-2019, 03:25 PM   #4
Yes, easy to do, I didnít know they were there but found a thread about it on this forum. You can use the search function to find the thread.
Old 05-03-2019, 04:30 PM   #5
Thanks. I will try that this weekend and let you know if it works.
Old 05-04-2019, 08:16 PM   #6
swilly43's Avatar
escondido , California
Donít bother
I replaced this light strip once. It failed again and I thought why bother. Poor implementation of a vanity feature. Not worth the effort. I live in San Diego with limited exposure to wet environments
swilly43 is offline   Reply With Quote
58 PVC under carriage Bernardkayes VAC | Vintage Airstream Club 2 09-02-2015 02:22 PM
Something hanging from the under carriage k9jackie Sprinter and B-van Forum 7 07-15-2015 03:45 PM
under carriage carrier MontyV 1993-1997 Limited 1 07-15-2013 10:21 PM
08 carriage air stream 2 slides body paint awesome!!! eBay Watch Airstreams on eBay 0 05-20-2011 09:00 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
