Old 08-04-2016, 06:58 PM   #1
southjk's Avatar
2015 Interstate Grand Tour
midland , Texas
Tv antenna 2015 grand tour
The black round plastic thing wobbles and appears loose. Can't see where it tightens or is suppose to be that way.
southjk is offline   Reply With Quote
Old 08-04-2016, 11:07 PM   #2
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Mine seemed like a miniature version of a Tilt-a-Whirl and IIRC, I turned it CW to tighten it. Since it's not here any longer, I can't verify it. If that doesn't work, look around and underneath it for any fasteners that can be tightened.
Glass half full or half empty to an engineer is the glass is twice as big as it needs to be.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
73shark is offline   Reply With Quote
Old 08-05-2016, 07:33 AM   #3
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
It Might Be Loose
Mine went MIA somewhere around Tucson AZ last year. Have been meaning to look at the replacement Airstream installed.
Ron_CA is offline   Reply With Quote
Old 08-07-2016, 03:26 PM   #4
Ron_CA's Avatar
OK had the 8 foot stepladder out for another task so decided to take a look.
Antenna is wobbly and is held on by a pressure clip that doesnt hold it real secure. It can also spin but doing so would only result in twisitng the coax.
Old 08-07-2016, 04:26 PM   #5
Anywhere USA , USA
Yes, I encountered the clip Ron is talking about when I had to move the antenna to the top of my AC cover. I used a dremel cut off wheel to cut through both the plastic base and clip. It feels very loose but was very difficult to remove and the metal shaft is keyed to prevent rotation.
JayP is offline   Reply With Quote
Old 08-08-2016, 06:34 AM   #6
southjk's Avatar
midland , Texas
Does it need to wobble for a reason. Thinking of just wrapping some duct tape around the boom .
Old 08-08-2016, 10:47 AM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
It doesn't need to wobble. My Winegard antenna has a tripod base instead of a pedestal base, and doesn't wobble at all. Until I saw the photos of the pedestal base, I didn't even know that some Interstates had one. Wonder when they made that change (which definitely wasn't an improvement)?
Old 08-08-2016, 11:54 AM   #8
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
I think they made that change with the Grand Tour with the larger solar panel installed where the original antenna was located. The newer antenna is more in the middle of the roof.
UKDUDE is offline   Reply With Quote
Old 08-08-2016, 07:14 PM   #9
Ron_CA's Avatar
They made the change for the 2015 Model year AIs and GTs.
Old 08-09-2016, 05:24 AM   #10
Anywhere USA , USA
You can add duct tape to stop the wobbling, not sure how long the tape would last, couple weeks or so depending on weather but IMO there is no reason to add the duct tape. The antenna may be wobbly but it is also very securely fixed.
Old 08-09-2016, 08:22 AM   #11
Ron_CA's Avatar
See post #3 above. I lost faith that day
Old 08-09-2016, 09:47 AM   #12
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
I think Winegard discontinued the antenna we have on the pre-2015 Interstates. Too bad because it works great. I'm always amazed at how well it can pull in distant stations without the need to point it directionally.
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
Boxster1971 is offline   Reply With Quote
Old 08-09-2016, 03:10 PM   #13
73shark's Avatar
Gorilla tape would be good for at least a year outside. Great stuff it is. (Apologies to Yoda)
Old 08-09-2016, 05:18 PM   #14
southjk's Avatar
midland , Texas
I was thinking the exact thing!
2015 interstate grand tour problems plus! zingara Sprinter and B-van Forum 69 09-26-2015 02:12 PM
2015 Grand Tour Kenwood & Internet access curmugeon Sprinter and B-van Forum 3 07-29-2015 07:53 PM
Screens for 2015 Grand Tour tlundell Sprinter and B-van Forum 11 05-25-2015 07:37 AM
2015 Airstream Interstate Grand Tour EXT 24 - Florida ineed2golf Airstream Classifieds 0 04-14-2015 07:00 AM
First trip in our new 2015 Interstate Grand Tour LizabethLane Sprinter and B-van Forum 40 10-29-2014 02:06 PM
