Old 05-19-2014, 06:26 PM   #1
2012 Interstate Coach
Redwood City , California
Turning on water heater
My husband has 'misplaced' the Airstream quick start manual. I'm hoping we find it soon. We've now had our 2012 Interstate for 39 days! Having lots of fun with it. We were going to take it out this weekend, and it would be neat to have warm water. How do we turn on the hot water heater? Thanks Annie
poodlelover is offline   Reply With Quote
Old 05-19-2014, 06:34 PM   #2
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Go to airstream.com look under service. They have your manual online. It will probably come in handy again.
Ron_CA is offline   Reply With Quote
Old 05-19-2014, 06:41 PM   #3
1994 30' Excella
2013 Interstate Coach
Grand Rapids , Michigan
Assuming yours is like my 2013....in the control cupboard, above the generator control is a panel with two switches, one has a lightning bolt which is for the electric element, the other switch has a flame symbol for gas. If you are hooked to power, just turn on the electric switch.
Otherwise turn on the gas switch. You will see the lamp glow red....pre-light phase, go off, lighting....if it comes back on you may need to turn it off for a few seconds and try again. When the flame is on you will be able to hear it.
Hope this helps. I type slow so if this isn't enough, I bet you can find a good video on you-tube,
Mike
fonman is offline   Reply With Quote
Old 05-19-2014, 08:06 PM   #4
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
And to add to Fonman's update, make sure you have fresh water in the tank, the pump is on, and water flows from the hot side of the tap. Ie you have filled the hot water tank.
Old 05-19-2014, 08:29 PM   #5
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
And to add one more check, make sure the hot water tank bypass valve is not in the bypass position or the tank won't fill. The HW bypass is located under the rear lounge (if you have the lounge model) and behind the black partition. Mine has a red/orange handle.
Old 05-20-2014, 05:31 AM   #6
BikerBill
Poconos of Pa , Pennsylvania
And don't forget to use the propane the gas valve needs to be ON. If its like the 2014/13 there is this black box behind the right wheel. Unscrew the knob on the front (don't remove it) and the door drops down and inside on the forward panel there should be a toggle switch. This needs to be ON for the propane tank to operate.
And OH yes, make sure you have ample propane. Inside the main controls panel there is one for checking your "levels" of all tanks, including propane.
Enjoy.
Bikerbill is offline   Reply With Quote
Old 05-20-2014, 08:43 AM   #7
Newbie
joemikeb's Avatar
Fort Worth , Texas
The manual for my 2013 says that if you have electric hookup, you can turn on BOTH the electric water heater element and the propane "…for faster recovery." You don't run out of hot water in the middle of a shower.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
joemikeb is offline   Reply With Quote
Old 05-20-2014, 01:39 PM   #8
2004 16' International CCD
Chicagoland , Illinois
I hope this link will take you to what you need:
http://www.airstream.com/wp-content/...ate-manual.pdf
Airrogant is offline   Reply With Quote
Heater turning to cold air in middle of night zenarmy Furnaces, Heaters, Fireplaces & Air Conditioning 6 05-04-2012 10:49 PM
Turning off Sureflow system when connected to city water bonginator Water Heaters, Filters & Pumps 18 05-06-2010 08:37 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Water pump turning on for just a second at a time. longdog Fresh Water Systems 10 09-15-2008 08:37 PM
Land Yacht turning into a water Yacht Jacob80 Sinks, Showers & Toilets 10 04-08-2007 08:48 PM
