Old 11-04-2013, 03:42 PM   #1
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
Turbo Hose Failure
Greetings all, my previous rv which was built on an 07 sprinter chassis experienced a turbo hose failure which put the coach into "limp home mode". After the dealer replaced the hose under warranty, I installed the Riordan Co turbo hose ends and had no further problems. At some point, Mercedes redesigned the turbo hoses making them longer and therefore more flexible. My question: has anyone had any turbo hose issues with the later model sprinters.
Thanks for any feedback.
Bill
c21bill is offline   Reply With Quote
Old 11-04-2013, 04:25 PM   #2
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
Bill,
Now why did you have to bring that up? I had almost put it completely behind me. But yes, my 2010 Interstate on a 2008 Sprinter chassis did have this problem. I was in the middle of BC and the tow to a dealer was a 12 hours & 525 miles which I had to pay up front ($2500) as the problem happened in Canada. I believe the part number of the replacement hose was the same part number on the one that failed and both were the newer version. It was the left side hose that failed on mine and the part installed was A 906-528-22-82. I don't know if that is the part used in newer builds or not. If you have access to EPC.net, you can enter your VIN and see which part is on yours. Or, PM me your VIN and I'll look it up for you.
Wayne
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
