Old 07-17-2014, 01:53 PM   #1
2010 22' Interstate
Vincennes , Indiana
Transmission and Brake Fluid
When, or do you, change the transmission and brake fluid in the Sprinter?
aa9zz is offline   Reply With Quote
Old 07-17-2014, 02:02 PM   #2
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
Trans fluid should be done every 80k or sooner. I use Shell 134 trans fluid (MB approved), instead of the dealer supplied fluid- much cheaper, and the gasket/filter set from Europarts of San Diego. Brake fluid flush every three years or so.
robert claus is offline   Reply With Quote
Old 07-17-2014, 02:03 PM   #3
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Typically a long time down the road (miles) for both. I would look in your manual and see if you can find it, as it may be in the maintenance schedule. Then Mercedes Sprinter service department.
Do you have reason to believe that it is time?
Ron_CA is offline   Reply With Quote
Old 07-17-2014, 02:43 PM   #4
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
My 2013 Maintenance Manual says the transmission fluid should be changed every 40,000 miles, and the brake fluid every 2 years.
Old 07-17-2014, 04:30 PM   #5
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
My 2011 manual says every other Service B (called Maintenance Service in the manual) which would be 40,000 miles for the tranny.
It says every two years to renew the brake fluid.
Do I change transmission fluid? Matt Kline Tow Vehicles 10 06-22-2010 07:33 AM
Metal in Transmission Fluid myfirstrv Mechanics Corner - Engines, Transmission & More... 17 03-12-2009 10:32 AM
Filling a new TH400 transmission with fluid bkahler Mechanics Corner - Engines, Transmission & More... 16 01-15-2009 03:26 PM
Synthetic Transmission Fluid AirHog Tow Vehicles 28 12-30-2008 11:15 AM
Transmission Fluid heating up neil.ervin Tow Vehicles 14 01-07-2005 08:33 PM
