Old 07-04-2015, 02:46 PM   #1
Tao
Tao's Avatar
2013 19' International
Chapel Hill , North Carolina
TPMS - Don't like looks the rear inner value stem!
In prep for the arrival of my TPMS, Tire Minder A1A, on Tuesday, I was looking at the valve stems used on the wheels.
The front a metal and should do fine for mounting the sensor on the existing stem. However, the rear dually's leave a lot to be desired in my mind. The inner wheel has just a cheap plastic extender that is fairly short added to a flexible rubber valve stem. I can imagine the extender cracking in no time from the centrifugal force that the sensor will add - thus a flat inner tire.
Am I the only one who finds this a poor setup?
If I'm not alone, what have others found as the best solution?
Thinking of taking AI to a truck tire dealership and having metal stems installed.
Tao is offline   Reply With Quote
Old 07-04-2015, 02:52 PM   #2
2011 Interstate Coach
Muskogee , Oklahoma
This is what I replaced them with for my TPMS:
DL1SPAL Chrome Dually Valve Kit
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 07-04-2015, 02:57 PM   #3
Tao
Tao's Avatar
Looks like a simple solution!
BUT $120!! Is that correct?
Old 07-04-2015, 03:02 PM   #4
Newbie
joemikeb's Avatar
2013 Interstate Coach
Fort Worth , Texas
FWIW I would not trust any but metal valve stems to put TPMS sensors on. I use the same ones as gmillerok1. The set has appropriate mounting for the steel inner wheels and aluminum outer wheels.
Make errors otherwise the Great Spirit realizes
you have finished your purpose on earth.
Navajo saying
joemikeb is offline   Reply With Quote
Old 07-04-2015, 03:34 PM   #5
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
Tao, you definitely want to go with G Miller's recommendation on the Dually Valves. They are around 120 bucks + another $75 or so to have them installed but they are a quality product that will properly handle the weight of the TPMS sensors. (use a quality tire shop that will take the time to properly align the inner tire stems).
I have used these on two Sprinter based rv's over the last 6 years with absolutely no problems.
c21bill is offline   Reply With Quote
Old 07-04-2015, 03:34 PM   #6
Muskogee , Oklahoma
Yep. Supply and demand. This is the only solution I am aware of. I even had a MB/Sprinter parts manager refer me to them after I couldn't find any solution at all on my own.
Old 07-04-2015, 04:01 PM   #7
Tao
Tao's Avatar
OK, I'll order them Tuesday from the link in the post.
Thanks for the input/solution.
Just to confirm, the linked item will work on the AI Grand Tour Alcoa outside rim AND the steel inner rim?
PS: Anyone using the Centramatic balancers on the rear dual wheels? If so, impressions or just stick with a good tire shops balance of each dual wheel separately?
Old 07-04-2015, 04:23 PM   #8
73shark's Avatar
Overland Park , Kansas
It probably wouldn't hurt to contact them if you're unsure of fitment.
Old 07-04-2015, 04:29 PM   #9
Muskogee , Oklahoma
If the wheels are the same size as the 2011 model, then yes. I think they are but you need to check with them or Airstream to be sure.
Old 07-04-2015, 07:22 PM   #10
Tao
Tao's Avatar
Will do on Tuesday.
Thanks again.
Old 07-04-2015, 10:43 PM   #11
I had the tire shop balance my wheels when they installed the Dually Valves and being as all 4 were out of balance I had them balance the fronts also. They were out as well.
Old 07-05-2015, 04:21 AM   #12
The Tire and Rim Association gives 65 psi as maximum pressure for standard rubber valves. Information on maximum pressure for various types of valves is here:
http://www.tirerack.com/tires/tirete...jsp?techid=208
I will only use steel valves on my truck, which has 80 psi maximum tires.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 07-05-2015, 05:05 AM   #13
Tao
Tao's Avatar
Safe to assume most of going with 61psi that Airstream recommends?
Old 07-05-2015, 08:57 AM   #14
2014 Interstate Ext. Coach
Bound Brook , New Jersey
Tao, I have used 61psi and it seems to work well for me
SCARLET BISON
Silver 2014.5 Interstate EXT
scarletbison is offline   Reply With Quote
This is what a desk for a Diplomat looks like joshua32064 Off Topic Forum 5 11-12-2003 10:58 PM
Looks like I've got a leak Stefrobrts Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-10-2003 04:10 PM
