Old 12-14-2015, 04:53 PM   #29
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Originally Posted by Protagonist View Post
That's a new one on me! My Interstate doesn't have any kind of rubber stabilizers that fit the slot in the outer wheels— never did. Any idea where I could buy some?
They came w/ my DL1SPAL Chrome Dually Valve Kit.
Old 12-15-2015, 01:07 PM   #30
Dalwyn's Avatar
2015 Interstate Grand Tour
Southaven , Mississippi
Originally Posted by 73shark View Post
Have the camber set as close to zero as the specs allow. This may require the special camber bolt that MB sells.
Question how do I determine if I will need the special camber bolt? Is this something that can be determined before the shop does the alignment or is it only determinable as part of the alignment? Just wondering if I should order before I take it in.
Dalwyn is offline   Reply With Quote
Old 12-15-2015, 03:31 PM   #31
73shark's Avatar
Will be determined during the alignment. He could align mine within spec w/o the special bolt but couldn't get it close to the "zero" side of the spec. Since I wasn't at a MB dealer, I had to leave it at that. Haven't put enuf miles on the tires to see if it was enuf to eliminate the excessive wear on the outside rib.
If you have yours done at a MB dealer, you could check to see if they have them in stock. I think they run about $8.00 ea.
Old 12-15-2015, 05:15 PM   #32
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
My dealer charged me $15 for a pair used during my alignment.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Boxster1971 is online now   Reply With Quote
This is what a desk for a Diplomat looks like joshua32064 Off Topic Forum 5 11-12-2003 10:58 PM
Looks like I've got a leak Stefrobrts Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-10-2003 04:10 PM
