Old 07-05-2015, 02:52 PM   #15
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Ditto. Would like to use less in rear to improve ride but don't have the weight slips and the tire specs so will keep 61 psi.
Old 07-05-2015, 04:48 PM   #16
Rockwell , North Carolina
Originally Posted by Tao View Post
In prep for the arrival of my TPMS, Tire Minder A1A, on Tuesday, I was looking at the valve stems used on the wheels.
The front a metal and should do fine for mounting the sensor on the existing stem. However, the rear dually's leave a lot to be desired in my mind. The inner wheel has just a cheap plastic extender that is fairly short added to a flexible rubber valve stem. I can imagine the extender cracking in no time from the centrifugal force that the sensor will add - thus a flat inner tire.
Am I the only one who finds this a poor setup?
If I'm not alone, what have others found as the best solution?
Thinking of taking AI to a truck tire dealership and having metal stems installed.
I had a problem with my inners after I added extensions to them. They broke the factory plastic extensions and both inner tires lost all of their air pressure. I was very fortunate the tires did not come apart. Which is why I installed TPMS. http://www.airforums.com/forums/f240...te-131097.html
jerhofer is offline   Reply With Quote
Old 07-06-2015, 05:37 AM   #17
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
One of the first things I replaced on my Interstate was the plastic valve extensions with metal ones. The plastic ones leaked from day one.
Old 07-07-2015, 11:58 AM   #18
Wayzata , Minnesota
Just to be clear, are you saying that any stem on which a TPMS is to be installed should/must be metal and not just the inside of a dually?
WendyW.
"I would feel more optimistic about a bright future for man if he spent less time proving that he can outwit Nature and more time tasting her sweetness and respecting her seniority." (E.B. White)
WendyW. is offline   Reply With Quote
Old 07-07-2015, 12:38 PM   #19
Newbie
joemikeb's Avatar
2013 Interstate Coach
Fort Worth , Texas
I don't know that the stems must be metal but IMHO they should be. Although the TPMS sensors do not weigh much the additional stresses imposed at highway speeds can be significant. Personally I feel a lot safer with metal stems and think they are well worth the cost to purchase and have installed.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
joemikeb is offline   Reply With Quote
Old 07-07-2015, 06:43 PM   #20
Boxster1971's Avatar
Fulton , Maryland
Most all makers of TMPS sensors that you attach to the valve stems tell you to use metal valve stems. Lesson learned: Advanced RV installs a TPMS on all their Sprinter van conversions. The just used the stock rubber valve stems at first until a customer had a flat in front tire caused by failed valve stem. They now install only metal valve stems with the TPMS they install.
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
Old 07-09-2015, 09:17 PM   #21
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
I had the same. After installing the TPMS both of my rear inner tire would loose air. Of course the TPMS did let me know.
Petet
PSchw is offline   Reply With Quote
Old 07-11-2015, 10:55 AM   #22
Raymond , Iowa
Before spending the $120 I want to me sure they'll fit:
The AI dual rear wheels are steel rim on the inner and aluminum rim on the outer. These DKL1SPAL work for that - correct?
The straight long one goes on the inner wheel (currently a rubber stem)l, with the rubber grommet going in the aluminum outer wheel and the inner stem is threaded through the grommet - for extra strength.
The 135deg one is a replacement stem for the outer rim - but is a bit unnecessary. My outer rim already has a metal stem, allowing me to screw a 135 deg extension onto it. This simply replaces the two-piece outer stem with a one-piece. Correct?
Titus is offline   Reply With Quote
Old 07-11-2015, 12:59 PM   #23
Fulton , Maryland
Titus - you are correct.
- - Mike
- - Mike
Old 12-14-2015, 09:58 AM   #24
Dalwyn's Avatar
2015 Interstate Grand Tour
Southaven , Mississippi
Originally Posted by c21bill View Post
(use a quality tire shop that will take the time to properly align the inner tire stems).
I have a 2016 Interstate Grand Tour Ext and believe the DL1SPAL is the one that fits my vehicle. I plan on ordering these and have the local tire shop (Gateway Tire) install these. I don't want to sound to dumb, but what is the proper alignment of the inner tire stems? They may know this, I just want to be able to tell them and also be able to visually see that they are installed correctly. I also plan to have all tire balanced, is this something most Interstate owners have done?
Dalwyn is offline   Reply With Quote
Old 12-14-2015, 12:42 PM   #25
73shark's Avatar
The inner extension comes straight out thru one of the "windows in the outer wheel. There's a rubber stabilizer that fits in the window and the extension comes thru the hole in it. There's really no alignment required.
Besides balancing, you should also get the front end aligned w/ the van loaded as close as possible to the normal travel weight. Have the camber set as close to zero as the specs allow. This may require the special camber bolt that MB sells.
Old 12-14-2015, 01:38 PM   #26
That's a new one on me! My Interstate doesn't have any kind of rubber stabilizers that fit the slot in the outer wheels— never did. Any idea where I could buy some?
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-14-2015, 02:05 PM   #27
Dalwyn's Avatar
The inner extension comes straight out thru one of the "windows in the outer wheel. There's a rubber stabilizer that fits in the window and the extension comes thru the hole in it. There's really no alignment required. Besides balancing, you should also get the front end aligned w/ the van loaded as close as possible to the normal travel weight. Have the camber set as close to zero as the specs allow. This may require the special camber bolt that MB sells.
Thanks appreciate the info.
Old 12-14-2015, 02:49 PM   #28
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
They come with the DL1SPAL Dually Valve Kit. You can check with
yourtireshopsupply.com to see if they are available seperately. One thing to consider is that over the years Airstream used different wheels with different size/shape hand holes and the stabilizers are specific to the hole configuration.
c21bill is offline   Reply With Quote
This is what a desk for a Diplomat looks like joshua32064 Off Topic Forum 5 11-12-2003 10:58 PM
Looks like I've got a leak Stefrobrts Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-10-2003 04:10 PM
