07-04-2015, 02:46 PM
2022 16' Basecamp
Chapel Hill
, North Carolina
TPMS - Don't like looks the rear inner value stem!
In prep for the arrival of my TPMS, Tire Minder A1A, on Tuesday, I was looking at the valve stems used on the wheels.
The front a metal and should do fine for mounting the sensor on the existing stem. However, the rear dually's leave a lot to be desired in my mind. The inner wheel has just a cheap plastic extender that is fairly short added to a flexible rubber valve stem. I can imagine the extender cracking in no time from the centrifugal force that the sensor will add - thus a flat inner tire.
Am I the only one who finds this a poor setup?
If I'm not alone, what have others found as the best solution?
Thinking of taking AI to a truck tire dealership and having metal stems installed.
07-04-2015, 02:52 PM
Muskogee
, Oklahoma
This is what I replaced them with for my TPMS:
DL1SPAL Chrome Dually Valve Kit
2011 Interstate WD/Lounge (since sold).
2020 Leisure Van WonderRTB
07-04-2015, 02:57 PM
2022 16' Basecamp
Chapel Hill
, North Carolina
Originally Posted by gmillerok1
Looks like a simple solution!
BUT $120!! Is that correct?
07-04-2015, 03:02 PM
Newbie
2013 Interstate Coach
Fort Worth
FWIW I would not trust any but metal valve stems to put TPMS sensors on. I use the same ones as gmillerok1. The set has appropriate mounting for the steel inner wheels and aluminum outer wheels.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
07-04-2015, 03:34 PM
2014 Interstate Coach
Arroyo Grande & Central Point
, California & Oregon
Tao, you definitely want to go with G Miller's recommendation on the Dually Valves. They are around 120 bucks + another $75 or so to have them installed but they are a quality product that will properly handle the weight of the TPMS sensors. (use a quality tire shop that will take the time to properly align the inner tire stems).
I have used these on two Sprinter based rv's over the last 6 years with absolutely no problems.
Muskogee
, Oklahoma
Yep. Supply and demand. This is the only solution I am aware of. I even had a MB/Sprinter parts manager refer me to them after I couldn't find any solution at all on my own.
07-04-2015, 04:01 PM
2022 16' Basecamp
Chapel Hill
, North Carolina
OK, I'll order them Tuesday from the link in the post.
Thanks for the input/solution.
Just to confirm, the linked item will work on the AI Grand Tour Alcoa outside rim AND the steel inner rim?
PS: Anyone using the Centramatic balancers on the rear dual wheels? If so, impressions or just stick with a good tire shops balance of each dual wheel separately?
07-04-2015, 04:23 PM
2011 Interstate Coach
Overland Park
, Kansas
It probably wouldn't hurt to contact them if you're unsure of fitment.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
07-04-2015, 04:29 PM
Muskogee
, Oklahoma
If the wheels are the same size as the 2011 model, then yes. I think they are but you need to check with them or Airstream to be sure.
07-04-2015, 07:22 PM
2022 16' Basecamp
Chapel Hill
, North Carolina
Will do on Tuesday.
Thanks again.
07-04-2015, 10:43 PM
I had the tire shop balance my wheels when they installed the Dually Valves and being as all 4 were out of balance I had them balance the fronts also. They were out as well.
07-05-2015, 04:21 AM
The Tire and Rim Association gives 65 psi as maximum pressure for standard rubber valves. Information on maximum pressure for various types of valves is here:
http://www.tirerack.com/tires/tirete...jsp?techid=208
I will only use steel valves on my truck, which has 80 psi maximum tires.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
07-05-2015, 05:05 AM
2022 16' Basecamp
Chapel Hill
, North Carolina
Safe to assume most of going with 61psi that Airstream recommends?
07-05-2015, 08:57 AM
2014 Interstate Ext. Coach
Basking Ridge
, New Jersey
Tao, I have used 61psi and it seems to work well for me
SCARLET BISON
Silver 2014.5 Interstate EXT
07-05-2015, 02:52 PM
Overland Park
, Kansas
Ditto. Would like to use less in rear to improve ride but don't have the weight slips and the tire specs so will keep 61 psi.
07-05-2015, 04:48 PM
Rockwell
, North Carolina
I had a problem with my inners after I added extensions to them. They broke the factory plastic extensions and both inner tires lost all of their air pressure. I was very fortunate the tires did not come apart. Which is why I installed TPMS. http://www.airforums.com/forums/f240...te-131097.html
07-06-2015, 05:37 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
One of the first things I replaced on my Interstate was the plastic valve extensions with metal ones. The plastic ones leaked from day one.
07-07-2015, 11:58 AM
Wayzata
Just to be clear, are you saying that any stem on which a TPMS is to be installed should/must be metal and not just the inside of a dually?
WendyW.
"I would feel more optimistic about a bright future for man if he spent less time proving that he can outwit Nature and more time tasting her sweetness and respecting her seniority." (E.B. White)
07-07-2015, 12:38 PM
Newbie
Fort Worth
I don't know that the stems must be metal but IMHO they should be. Although the TPMS sensors do not weigh much the additional stresses imposed at highway speeds can be significant. Personally I feel a lot safer with metal stems and think they are well worth the cost to purchase and have installed.
— Navajo saying
07-07-2015, 06:43 PM
2024 Interstate 19
Fulton
, Maryland
Most all makers of TMPS sensors that you attach to the valve stems tell you to use metal valve stems. Lesson learned: Advanced RV installs a TPMS on all their Sprinter van conversions. The just used the stock rubber valve stems at first until a customer had a flat in front tire caused by failed valve stem. They now install only metal valve stems with the TPMS they install.
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
