Originally Posted by jennian
all great info but the more I learn the more questions I have. has anyone used a tow dolly and any opinions versus towing flat?
There are pros and cons to tow dollies.
Pros—
No modifications needed to the toad— that's a big one because it doesn't affect the resale value of the toad;
You
can back up a toad on a dolly same as you can back a trailer;
Ideal for any front-wheel-drive toad, including models that can't be flat-towed;
If you have multiple cars that could be used as toads, one dolly fits all so no need to buy separate equipment for each toad;
Hooks up to the van just like any other trailer.
Cons—
Not ideal for toads with a long rear overhang;
Not usable at all for most four-wheel-drive toads;
Only two brakes instead of four so potentially less stopping power;
Usually doesn't come with a spare dolly tire;
Needs to be licensed and inspected as per your state's trailer regulations;
Brake lights and turn signals are mounted low and can be difficult for following drivers to see;
Adds to the weight being towed so not ideal for heavy toads;
Bounces and is noisy when the dolly is towed
without a toad on it;
Needs to be stored somewhere when not in use, both at home and at the campsite.
