Old 01-14-2015, 10:53 AM   #29
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I suppose it helps in my case that I installed my Koni shocks and front struts early onó rather, I had Mercedes Benz of Baton Rouge do it for me, and they did a front end alignment at the same time, even though the instructions with the Konis said that no realignment was necessary after installation.
Having gotten a front-end alignment with my full load (full fresh water tank, full propane, full diesel tank, everything but me in the driver's seat) is probably why I've not experienced the same problems as you describe.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-15-2015, 02:46 AM   #30
CapriRacer
CapriRacer's Avatar
I'm in the , US
Originally Posted by Moflash View Post
.......Under inflation will cause accelerated wear both inside and outside rib usually without cupping.Over inflation will cause accelerated wear in the middle of the tires tread.
Hope this helps.
That part isn't quite right.
First, there are other things that have a greater affect than inflation pressure. For example, steer tires tend to wear on the shoulders and drive tires tend to wear in the center. So even properly inflated tires will show symptoms that most folks would view as over/under inflation.
Inflation pressure does affect cupping. It's kind of a multiplier - too low and the cupping gets worse. It's not a direct cause, but it does affect the results.
CapriRacer is offline   Reply With Quote
Old 01-15-2015, 12:21 PM   #31
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I agree with you,just trying to simplify description for novice drivers.
Old 01-15-2015, 01:50 PM   #32
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
And weak shocks/struts can cause cupping.
Old 01-16-2015, 07:08 AM   #33
2010 22' Interstate
New Bern , North Carolina
Thanks!
Thanks for all the good advice and discussion on "Tires". I didn't realize I was opening a topic with so much interest and experience. Being new to the Forums I am impressed with how valuable this tool will be as I continue my adventures in the world of RVing. I am now at a Chrysler dealer that services Sprinter for front end alignment with new Michelin LT215/85R16 LTX MS2 tires.
Again, thank you all,
From the "Prairie Schooner"
Prairie is offline   Reply With Quote
Old 01-16-2015, 07:59 AM   #34
73shark's Avatar
Hope their rig can handle the long wheel base. Mine couldn't.
Tires...Tires...Tires Bob Thompson Tires 277 07-30-2015 01:30 PM
tires radials or bias ply tires larry b Tires 22 06-27-2010 05:36 PM
Tires ready to blow out! Should Marathon tires be outlawed? marchesi Tires 21 08-22-2009 10:11 AM
Help tires, tires, tires. jimmini Tires 9 10-18-2008 07:54 PM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 04:11 PM
