Old 01-12-2015, 09:20 AM   #15
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
MB doesn't put TPMS on the 3500 Sprinters because it is not required by US DOT. That could change in the future because US NHTSA is pushing to require TPMS on all road vehicles.
- - Mike
Old 01-12-2015, 07:46 PM   #16
Brucet45410's Avatar
2014 Interstate Coach
Norfolk , Virginia
A TPMS is certainly high on my list of modifications. What are the preferred choices in TPMS that have been purchased by the forum?
Wherever you go, there you are!
Brucet45410 is offline   Reply With Quote
Old 01-12-2015, 07:58 PM   #17
2010 22' Interstate
New Bern , North Carolina
Thanks Heliskier. We have the same vehicle with Kumho original equipment tires and I have decided to replace all six tires with Michelin LTX MS2. Have you driven enough on the new tires to get an idea if the cupping and singing noise might retun? $1400 is worth the peace of mind and quiet ride. How many miles did you get on thru Kumhos?
Prairie is offline   Reply With Quote
Old 01-12-2015, 09:48 PM   #18
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
I believe the cupping is due to an alignment issue. Anytime you purchase new tires for a vehicle, you should get it aligned.
Old 01-13-2015, 07:32 AM   #19
2010 22' Interstate
Oak Lawn , Illinois
Prairie,
I only had 25,000 miles on the tires before I replaced them. I figure since it was a 2008 chassis that it probably sat in Jackson center's parking lot before I got it. So the tires were at least 5 years old. I think if you look closely at your sidewalls, you will see tiny dry rot cracks starting to develop.
The cupping is from the alignment. You should also allocate another $200 for an alignment. Peace of mind is not cheap unfortunately.
I only have 5,000 miles on the tires now. No signs of cupping or humming noise. I don't expect to have any issues.
rvheliskier2 is offline   Reply With Quote
Old 01-13-2015, 08:05 AM   #20
Fulton , Maryland
There are a number of TPMSs available. Most aftermarket models have sensors that screw on to end of tire valve stem in place of a cap. I have the TST system with flow-thru sensors. There are internal sensors available much like the OEM systems, but they are difficult to install - because they require removing the tires from the rims to install the sensors. If you get the valve cap sensors make sure you replace the rubber valve stems with metal stems. The weight of the sensors cap will cause the stock rubber valve stems to fail - giving you an instant flat tire.
- - Mike
Old 01-13-2015, 10:47 AM   #21
Newbie
joemikeb's Avatar
Fort Worth , Texas
I have been told by three reputable tire stores that "cupping" is endemic on vehicles made in Germany including Mercedes, BMW, and Volkswagen. The implication being U.S. built models from the same manufacturer are not as likely to evince the problem. No explanation of why that is was offered, but the solution offered is being sure to rotate the tires often. It does not eliminate the cupping, but equalizes the wear.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
joemikeb is offline   Reply With Quote
Old 01-13-2015, 11:07 AM   #22
73shark's Avatar
Probably a conspiracy between the Germans and the tire manufacturers.
I wouldn't be so paranoid if everyone wasn't out to get me.
My front tire wear was confined to the outer rib and was uniform, not cupped. From what I've been told over the years was that cupping was usually caused by worn shocks.
Old 01-13-2015, 02:58 PM   #23
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
As far as I know, every Sprinter van comes off the same assembly line in Dusseldorf, so that would be a moot point. There are no American-made Sprinters that I know of.
I haven't seen any uneven tire wear at all on my Interstate. No cupping, no excessive outer edge wear, no excessive inner edge wear, nothing.
Mind you, I only have 20,000 miles on mine, so maybe it's a problem that will show up as I get more use out of it…
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-13-2015, 05:07 PM   #24
Fulton , Maryland
Cupping normally means your tires are not balanced properly. Uneven wear on front is normally an alignment problem. I've have no such problems with my new Michelins in over 15,000 miles.
- - Mike
Old 01-13-2015, 07:17 PM   #25
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Tires
If your tires are cupped on just the outside edges or inside edges your vehicle is out of alignment.You can rotate them but they will not ever smooth out and will whine until replaced.Replace front tires and align and all will be good again.
Old 01-13-2015, 10:30 PM   #26
73shark's Avatar
Could you elaborate on which element(s) of alignment (caster, camber, toe) contribute to cupping?
Old 01-14-2015, 05:03 AM   #27
CapriRacer
CapriRacer's Avatar
I'm in the , US
Mostly it is toe. Camber can play a role, but to a lesser extent. Where it gets interesting is that both camber and toe can reinforce each other and the result would be worse than the sum of the 2 by themselves.
CapriRacer is offline   Reply With Quote
Old 01-14-2015, 09:43 AM   #28
Moflash's Avatar
Tires
To much toe in will cause excessive outside tire rib wear with cupping toe out will cause excessive inside rib wear with cupping.Excessive camber will cause more even excessive wear without cupping normally on the inside or outside of tires tread.Under inflation will cause excellerated wear both inside and outside rib usually without cupping.Over inflation will cause excellerated wear in the middle of the tires tread.
Hope this helps.
Tires...Tires...Tires Bob Thompson Tires 277 07-30-2015 01:30 PM
tires radials or bias ply tires larry b Tires 22 06-27-2010 05:36 PM
Tires ready to blow out! Should Marathon tires be outlawed? marchesi Tires 21 08-22-2009 10:11 AM
Help tires, tires, tires. jimmini Tires 9 10-18-2008 07:54 PM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 04:11 PM
