Old 05-23-2015, 06:42 PM   #29
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
All of the vehicles I've owned w/ aluminum wheels stated in the owner's manual to re-torque the lug nuts after 50 miles. Probably not a bad idea w/ steel wheels but not as necessary.
Old 05-23-2015, 06:54 PM   #30
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by Boxster1971 View Post
### Advice to all new Interstate owners. Take your Sprinter to a good dealer or alignment shop and have the front camber reset. Mercedes sets the camber in the factory on an empty van. Then Airstream loads it up to nearly 10,000 pounds and the front camber is no longer correct. Airstream should fix this but they don't. ###
When I had my Koni shocks and struts installed at my Mercedes dealer, they did a front-end alignment as part of the deal. That may be one reason I've never experienced the uneven tread wear that some others have.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-24-2015, 08:41 AM   #31
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
My front tires been worn out with 25k replaced it with Michelins and had the front realigned twice until the changed the alignment on the chamber from -1 to +1 now it runs great and even wear on the front Michelins adding a 30k. The rear still look ok with the original Continentals. Watching the shop changing out my front tires I don't want the to touch them anymore then I have to. The Alcoa are a little tricky to put on and if it is not done right it destroy them. They don't take the covers of the locknuts which leads to you gone lose them so I replaced my locknuts with chrome once without a cover.
PSchw is offline   Reply With Quote
Old 05-26-2015, 08:19 PM   #32
X New Yorker
X New Yorker's Avatar
2013 Interstate Coach
Springfield , Massachusetts
I'm just really happy to have one... and I love her!
X New Yorker is offline   Reply With Quote
Old 05-31-2015, 09:30 AM   #33
Lafayette , Louisiana
tire rotation
Boxter1971, are you saying the steel spare tire/rim will fit any of the 6 tire/rims as a quick fix for a flat? I assumed it was only a quick fix for the inner dually rims and would require taking the tire off of the spare and transferring it over to any of the 4 Alcoa rims. Obviously not a roadside job.
Thanks for any info.
drgene is offline   Reply With Quote
Old 05-31-2015, 04:49 PM   #34
Boxster1971's Avatar
Fulton , Maryland
Yes - the spare will fit on any of the six wheel positions.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Trailer Tire Rotation moosetags Tires 11 05-02-2015 09:10 AM
Tandem axel tire rotation ?? polarlyse Wheels, Hubs & Bearings 13 05-02-2015 06:03 AM
First rotation xo1rider Tires 4 06-04-2012 07:42 AM
Dually Tire Rotation Maryw164 Tow Vehicles 9 04-05-2010 05:38 AM
