Old 01-01-2013, 02:05 PM   #1
2012 Interstate Coach
Front Royal , Virginia
Tire Pressure Gauge
Hi All,
What type of tire pressure gauge do you use on your Interstate with dual rear wheels?
SGT DAVE
SGT DAVE is offline   Reply With Quote
Old 01-01-2013, 03:02 PM   #2
Figment of My Imagination
Protagonist's Avatar
Slime¸® digital dual-chuck truck pressure gauge. Push to check the inside tires, pull to check the outside tires.
Name:	truck tire pressure gauge.jpg
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-02-2013, 05:15 PM   #3
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Welcome to the forum.
Here's what I got. Tire gauge
Checked against a known good digital and put red-line at 65 psi. It was only 1 psi off. YMMV
Old 01-02-2013, 07:09 PM   #4
r carl's Avatar
Lin , Ne
I use this one because its the standard in tire shops and made in USA. It wont fall apart or read incorrectly like a china one.
Milton Deluxe Service Dual-Head Tire Gauge — 10–160 PSI, Model# S-976 | Air Chucks Gauges| Northern Tool + Equipment
I also use this one too.
http://www.maxtool.com/us/products/MIL506.asp
Old 01-02-2013, 07:30 PM   #5
I thought about "Buy American" until I realized that my Airstream Interstate is proudly made in Germany (chassis, drivetrain), Canada (water heater, side windows), Sweden (galley sink), Italy (awning, retractable step), Japan (dashboard stereo), England (cooktop), China (upholstery), Korea (television), and who knows what other countries. Some of the Interstate was even made in the USA, like the rooftop vent fan, the generator, and the solar panel. With that in mind, as long as it's accurate, and measures in PSI that I am familiar with, it doesn't much matter where my tire pressure gauge was made.
WBCCI #1105
TAC LA-4
Old 01-02-2013, 08:23 PM   #6
73shark's Avatar
Milton Dual Chuck Tire Inflator With Gauge MIL506
Have you checked it for accuracy?
Old 01-07-2013, 04:18 PM   #7
Denis4x4's Avatar
Durango , Colorado
Made my own 25 years ago that allows me to add or drop pressures. Parts were about $40 and it is accurate as well as easy to read.
Denis4x4 is offline   Reply With Quote
Old 01-07-2013, 04:27 PM   #8
Nice, but for the duals on an Interstate, we'd need a double chuck. Or valve extensions. I recently opted for the extensions, but used the double chuck for the first year of ownership.
WBCCI #1105
TAC LA-4
Old 01-07-2013, 06:49 PM   #9
73shark's Avatar
Were the extensions U-shaped?
Old 01-08-2013, 03:27 AM   #10
Inside extensions were straight. Outside extensions were J-shaped.
WBCCI #1105
TAC LA-4
Old 01-08-2013, 09:34 AM   #11
r carl's Avatar
Lin , Ne
I called a couple tire shops last year to see if I could get my tire guages checked for accuracy and they all said they had no way to check for me so I just put it off. This morning I decided I better get it done so I put together a manifold with an expensive accurate guage. I checked a tire on my truck and it had 60psi. I checked the tire pressure with the 2 guages with hoses and my reading was 65psi with both. Then I checked the tire pressure with the 2 short guages and they both read 55psi. Lastly I checked the tire pressure with the long guage just below the manifold in the pic and it read 60psi. That guage is the most common guage in tire shops, I remember them when I was a kid. So that one is the one I recommend and use.
Old 01-08-2013, 10:16 AM   #12
Ottawa , ON
That's quite a swing, 10 lbs!
Now I'm going to look at the gauges I have and see how closely they agree.
Old 01-08-2013, 10:57 AM   #13
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
rcarl,
Are those valves on each side of the liquid guage?
Who manufactures the long tire guage in the center?
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 01-08-2013, 02:40 PM   #14
73shark's Avatar
Originally Posted by crispyboy View Post
rcarl,
It looks like the Milton gauge referenced in post #4. Or like the knock-off one I got from Harbor Freight.
