Old 09-21-2016, 01:43 PM   #15
Mel
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Three years ago, I purchased a "NVision" TPMS from a local RV dealer. ($500)
It too used four sensors, one for each wheel, that had to be 'introduced' to each tire position.
For the first year it worked ok, giving me tire pressures and a green light saying 'everything is good'.
The second year, I would get an orange light occasionally on the RT. FRONT tire, then it would go to green for awhile, then orange.
I swapped sensors, to see if the 'snag' followed the sensor, but no; it showed RH. FWD. all the time.
I then purchased a new set of two sensors, ($190) and tried one on the RH/FWD tire.
STILL got orange light, occasionally changing to green when underway.
I stayed with this unit, reasoning that as long as it didn't show Red, I could live with it.
This year, I got a RED light, (tire checked OK) then after awhile green/orange/green when underway. PHOOEY!
At a local speed shop, I purchased ANOTHER 'NVision' TPM. ($429), and after an hour with the tech rep in Kansas, was able to get the machine to accept the sensors. This, after using one of the spare sensors, that I had previously purchased.
I wanted the security of knowing my tire condition, because of a planned trip to Sudbury; a long way away.
The next day, when underway, the 'NVision' did not work at all, showing me no tire information. That was enough! So..........
Upon return to Blenheim, it took me two weeks to get a refund from the store for the second set, and I sent the original one back to the Mfgr. so the Engineers can figure it out.
I'm now using a set of tire pressure valve caps from Amazon, that show green band at 50 PSI, and red lower.
I now have an excuse to do an occasional 'walk-around'.
They will be tested out this weekend on another trip.
MelGoddard is offline   Reply With Quote
Old 09-21-2016, 02:57 PM   #16
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
Originally Posted by MelGoddard View Post
Now you got my curiousity!
What Airstream uses "Dually" wheels??
Airstream Interstate touring coach which is what this forum is all about. Seems like you have an Airstream Travel Trailer. Different Forum.
c21bill is offline   Reply With Quote
Old 09-21-2016, 08:21 PM   #17
Mel
[QUOTE=c21bill;1854645]Airstream Interstate touring coach which is what this forum is all about. Seems like you have an Airstream Travel Trailer. Different Forum.[/QUOTE
Curious statement
Yes, I do have a travel trailer, but......
I thought that the Forum was about ALL Airstreams.
Old 09-21-2016, 09:10 PM   #18
[QUOTE=MelGoddard;1854804]
Curious statement
Hi Mel, there are actually several forums under the general heading "Air Forums" This forum is called "Sprinter and "B" Van Forum" which is a sub-category of the "Airstream Motorhome Forum". Of course anyone is allowed to participate but you will find a lot of discussion here that is not relative to the trailers.
Old 09-21-2016, 09:59 PM   #19
New Borockton , Alabama
Images: 21
"Fussy sensor syndrome?"
Randy 208-514-8950
www.bestconverter.com
Converters, Inverters, Trimetric, EMS, Zamp Solar, Lifeline Batteries
Old 09-23-2016, 06:12 PM   #20
RMB
RMB's Avatar
2010 23' International
Saturna , British Columbia
I have the Doran system..... No complaints at all.
I was a bit concerned about sensor battery life but after three years in heat and cold - they still function fine.
It was easy to set up and its easy to mothball.
Cheers
"All that is mine, I carry with me." Cicero
RMB is offline   Reply With Quote
Review of a temperature monitoring / alert system barrettjl The Pet Forum 4 05-06-2014 11:01 AM
Dill Tire Pressure Monitoring System wingfoot321 Tires 3 12-14-2011 08:03 PM
Tire Pressure Monitoring system chirocruzr General Motorhome Topics 10 04-17-2009 10:08 AM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 08:55 PM
PressurePro Tire Pressure Monitoring System 68 Overlander Commercial Listings 21 09-21-2007 04:49 PM
