Old 10-29-2014, 08:06 AM   #1
Clifton , Virginia
Tire Pressure
Does anybody know what the proper tire pressure is on the Interstate? I have mine at 80 psi because that's how the dealer had it, but I also read on this forum somewhere that it should be 61. Any down side to keep driving at maximum pressure other than rougher ride? My thought is I don't have to worry about inflating the tires when I load up the van, if it's already at 80 psi.
cjrdad is offline   Reply With Quote
Old 10-29-2014, 08:15 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Weight each axle and use the inflation chart. Note all tires of the same size can use this chart independent of manufacture.
The pressure noted on the sidewall of a tire is a Max. The pressure noted on the vehicle door does not consider the load and may be high or low depending on that.
http://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
2004 Excursion 4x4
Old 10-29-2014, 08:17 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
On the Sprinter 3500 chassis, 61psi is the correct pressure on all six LT215/85R Spped Range Q tires, according to page 283 of the Spinter Operator's Manual.
On the Sprinter 2500 chassis, however, the front tires should be at 47psi and the rear tires at 70psi.
If you over-inflate the tires, two important things happen:
1 - You get excessive tire wear in the center of the tread;
2 - You have reduced braking effect because you've got too little tread in contact with the pavement; this also reduces the effect of the Electronic Stability Control system.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-29-2014, 08:23 AM   #4
Clifton , Virginia
Wow, such quick replies! Thank You!
I was hoping I didn't have to deal with weighing the van... Oh well.
Old 10-29-2014, 08:28 AM   #5
If you go by the Sprinter Operator's Manual, you don't have to weigh it.
WBCCI #1105
TAC LA-4
Old 10-29-2014, 08:43 AM   #6
Clifton , Virginia
But does the Sprinter van manual take into account all the added weight of the Interstate conversion?
Old 10-29-2014, 08:45 AM   #7
It's based on the Gross Axle weights, so it accounts for fully-loaded vans. If anything, it would leave tires slightly over-inflated for the empty condition of a baseline Sprinter.
WBCCI #1105
TAC LA-4
Old 10-29-2014, 08:50 AM   #8
Clifton , Virginia
61 it is then. Thank you.
Old 10-29-2014, 08:56 AM   #9
Gainesville , Florida
Those pressures seem awfully low for a van loaded to the max. Jim
Old 10-29-2014, 09:02 AM   #10
That's what I've been using on my Interstate for the past three years, with no problems at all. The ride is fine, handling is fine, tire wear is uniform across the entire width of all six tires. Tires do not get hot (a sure sign that they're under-inflated); in fact, here along the Gulf Coast, the tires are often cooler to the touch than the pavement they're running on.
WBCCI #1105
TAC LA-4
Old 10-29-2014, 10:17 AM   #11
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
I inflate mine to 61 or 62 psi. Seems to ride well and handle the load fine. Tires appear to be wearing evenly as well.
Ron_CA is offline   Reply With Quote
Old 10-29-2014, 10:52 AM   #12
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
61 psi works for me.
Old 10-29-2014, 07:14 PM   #13
Tulsa , Oklahoma
I'm good with 61/62 psi
Road Jager
Living On Tulsa Time
RoadJager is offline   Reply With Quote
Old 10-29-2014, 08:20 PM   #14
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
As a side question, what do you all use to ensure you get your pressures this accurate?
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 08:34 AM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 07:55 PM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
Tire Pressure thenewkid64 Tires 1 03-31-2002 01:44 PM
