Old 04-21-2015, 09:21 PM   #43
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
You're correct. Cupping is usually caused by toe, shocks, and balance. Mine weren't cupped, just wearing the outer rib off evenly. Wasn't paying attention when I posted before.
Old 04-22-2015, 05:17 AM   #44
CapriRacer
CapriRacer's Avatar
I'm in the , US
Just an FYI:
The term "cupping wear" is frequently misused to describe several different types of irregular tire wear, including one that is caused strictly by alignment. Even perfect round and perfectly balanced tires can get this type of wear.
CapriRacer is offline   Reply With Quote
Old 04-23-2015, 08:43 AM   #45
2006 37' A-Series
Cumming , Georgia
Does anyone run the TST TPMS? It will allow you monitor all your tires while your driving. Increase Tire Life, and know of problem before it becomes catastrophic. Monitors temp. as well.
Any questions feel free to ask or call me at 770-889-9102
Mike TST
mikeTST is offline   Reply With Quote
Old 04-23-2015, 12:13 PM   #46
Newbie
joemikeb's Avatar
2013 Interstate Coach
Fort Worth , Texas
Mike TST
I run it and so far it has worked well. No problems, no complaints.
Make errors otherwise the Great Spirit realizes
you have finished your purpose on earth.
Navajo saying
joemikeb is offline   Reply With Quote
Old 04-23-2015, 02:43 PM   #47
Boxster1971's Avatar
Fulton , Maryland
Mike TST
Hi Mike,
I have the TST Sytems on my Interstate. It works great and has given me the ability to avoid the risk of running a tire flat as I did last spring. Before I installed your TPMS I had an inner dual tire go flat for some unknown distance. I checked the tires OK when heading out in the morning and again at a mid-day rest stop where I discovered the flat.
Mine is the 507 model with flow-thru sensors and I have a question. The owners manual says you should get a Sensor Low Battery Indication. I had one sensor stop giving me information so I assumed it was a bad battery since they have been on my van for about a year now. When I opened up the sensor to change the battery I discovered that a bit of water had got inside and caused some corrosion. That old battery was down to 1.5 volts.
Any clue why I didn't get a Sensor Low Battery Indication?
I cleaned it up and installed a new battery and now it is working fine. I also changed all the other sensor batteries and none had any water or corrosion inside. The other cells were all at 3.0 volts. The new batteries were at 3.2 volts. So all is good but I'd like to understand why I didn't get the Sensor Low Battery Indication.
- - Mike
2013 Interstate on 2012 Sprinter
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 08:34 AM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 07:55 PM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
Tire Pressure thenewkid64 Tires 1 03-31-2002 01:44 PM
