Old 08-24-2015, 09:31 PM   #1
2014 27' Flying Cloud
Seguin , Texas
Tire gauge
Never had dual rear wheels before and having a heck of a time finding a tire gauge that is shaped right to check the psi on the outer tire. Where have you found one that works?
Also, stupid question....
For the inside tire is the plastic extension coming from the valve stem just a "marker" showing you where the valve stem is on the inner tire and then you unscrew that to check the pressure. Or, are you supposed to be able to use the tire gauge to check the psi thru the extension?
Laidback1 is offline   Reply With Quote
Old 08-24-2015, 10:19 PM   #2
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
You need a dual head tire gauge to check the outside dual. Here's an example.
Yes, you check the inside dual thru the plastic extension. I'd recommend getting the plastic extension replaced w/ a metal one cuz a piece of road debris snaps it off, there goes the air.
Old 08-25-2015, 10:01 AM   #3
Seguin , Texas
Hmmm
I'll just have to find the correct dual head tire gauge then. The One I have does not have the correct angle needed to work with the slots in the Alcoa wheels
Thanks for the tip on replacing the extenders to metal. Will do
Mark
Old 08-25-2015, 10:40 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Any auto parts store should be able to fix you up.
MICHAEL
Old 08-25-2015, 12:12 PM   #5
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Yes, the Milton dual head gauge as recommended by 73shark is a service gauge, meaning it's recommended for tire shops and heavy duty use. It's as accurate as they come.
Old 08-25-2015, 01:03 PM   #6
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Beyond changing the inner rear tire valve extension to metal - I recommend you get the entire OEM rubber valve stem on the inner duals replaced with metal valve stems. IMHO those ripper valve stems are a weak point. I had an inner dual go flat on me due to a crack in the rubber valve stem. They are rated for 65 psi and don't give much margin over the recommended 61 psi tire pressure.
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
Old 08-25-2015, 03:34 PM   #7
PaulG_4307's Avatar
2012 22' FB Sport
Camper Clinic II in Buda TX installed a TireMinder pressure monitoring system on our Bambi. This provides tire pressure readings on a remote display and Warnings if pressure drops 5lbs or more.
PaulG_4307 is offline   Reply With Quote
Old 08-25-2015, 05:17 PM   #8
Rockwell , North Carolina
I bought this one and it works great.
TireMinder Digital Tire Gauge - TireMinder TMG-DUAL-2 - Tire Accessories - Camping World
jerhofer is offline   Reply With Quote
Old 11-12-2015, 09:26 AM   #9
Dalwyn's Avatar
2015 Interstate Grand Tour
Southaven , Mississippi
Does anyone know if the outer rear dual tire stem can be replaced with a angled one? I am having a very difficult time putting air into the outer rear tires on my 2015 Interstate Grand Tour.
Dalwyn is offline   Reply With Quote
Old 11-12-2015, 10:28 AM   #10
73shark's Avatar
You need a double-ended chuck to air up the outer dual.
Available at most auto stores and BORG.
Old 11-12-2015, 10:30 AM   #11
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Yes, you can install a "J"-shaped extender. I did, and it works just fine.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-12-2015, 10:32 AM   #12
Depere , Wisconsin
Dual metal stems
On another thread, they recommended chrome metal stems for outer ALCOA wheels and steel inner wheels. I purchased a set of 4 #DL1SPAL from duallyvalve.com. They come with oval stabilizer for outer wheels that contain the inner chrome stems and also curved stems for the Alcoa wheels. I had them installed by my local sprinter technician. They work fantastic and now no air loss. An additional benefit is I can stop at any "gas station" and use their standard air chuck.
summerwood is offline   Reply With Quote
Old 11-12-2015, 10:46 AM   #13
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
Ditto what Summerwood recommended. Best possible upgrade for your tire stems with the added benefit of being able to add tire pressure monitors to the new steel stems. I have used the Dually Valves on two rv's with absolutely no issues.
c21bill is offline   Reply With Quote
Old 11-15-2015, 05:43 PM   #14
Ynefel's Avatar
Salem , New Hampshire
Question
This is the first time I've owned a dual wheeled vehicle. I've gone to the recommended website and see two long stems & two 'J' stems for the listed part. The set is $120. Is that all I need to order for a 2016 AS GT Ext?
-Robert
Ynefel is offline   Reply With Quote
Air Compressor & Tire Gauge JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 3 01-22-2014 01:24 PM
Tire Pressure Gauge Recommendation Jodason Sprinter and B-van Forum 9 08-18-2013 04:11 PM
Tire Pressure Gauge SGT DAVE Sprinter and B-van Forum 17 01-08-2013 11:07 PM
Propane tank gauge Jim Miller LP Gas, Piping, Tanks & Regulators 6 04-09-2003 04:25 PM
Refrig pressure gauge. casarodante Refrigerators 5 07-08-2002 11:04 AM
