Old 05-04-2016, 12:57 PM   #1
Ticking sound coming from battery box area
Hello. There is A ticking sound coming from the area in which the main battery switch is located. I believe it has something to do with the propane. When the propane shut off valve is turned to off, there is no noise. However when I turn it on, the ticking is heard once again. Any help? I need to add that it is a 2014 airstream interstate
Hammertime is offline   Reply With Quote
Old 05-04-2016, 01:06 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Is this when ever the propane is turned on or only while you are using, a gas flow, propane with anything in the unit.
2004 Excursion 4x4
Old 05-04-2016, 01:08 PM   #3
Howie, I hear the noise even when I am not using a gas flow. I tried running the stovetop burner to see if it would make a difference, and there was no difference.
Old 05-04-2016, 01:56 PM   #4
Houston , Texas
Do you have Solar? If so it could be the Solar Controller cycling on and off which is normal.
Mcrider is offline   Reply With Quote
Old 05-04-2016, 02:00 PM   #5
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Is it a ticking or a clicking sound? And what's the frequency? If you're parked in the sun, the solar controller clicks every 4 minutes, I think.
Update - Mcrider, you beat me to it!
Old 05-04-2016, 02:42 PM   #6
It was a constant clicking. Like a ticking time bomb. I noticed the house battery was almost dead and since then connected it to shore power and it stopped after it got charged, so I'm happy about that, but curious as to why. Thanks for your help!
Old 05-04-2016, 04:05 PM   #7
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Could it be related to this same root cause?
http://www.airforums.com/forums/f520...ea-148436.html
SeaLevel is offline   Reply With Quote
Old 05-04-2016, 04:42 PM   #8
OP has a late model Interstate and so it should have a fully-electric fridge, right? So it should NOT be a fridge piezo mis-firing?
As you both said, yes, the solar controller clicks. Ours certainly does, and much more frequently than every 4 minutes. It can be a bit unnerving. I always know when a passing cloud is imminent because the frequency changes before I even see a shadow.
However, we also had an issue (before my husband adjusted it) of the solar surcharging the refrigerator slightly. He measured voltages and it was well within the stated tolerances for that kind of Dometic. But it would trigger the danged piezo in a disconcerting manner, even if the gas was already ignited. Click, click, click until I wanted to say STFU.
Anywhere else there could be a piezo in the OP's model of Interstate?
Old 05-04-2016, 07:07 PM   #9
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
When I had that same problem, Airstream replaced the BIM and then the solar controller to fix it. Since the BIM replacement didn't help, I'm betting on the solar controller. If you're out of warranty and your model uses the PVCM25D Charge Controller, call Atkinson Electronics. I talked w/ Robert Kendal and explained my problem (which the second time was different than the first). He sent me a new one and only asked that I return the old one for failure analysis. Wished all companies had that kind of customer service.
Here's my thread dealing w/ this problem. Good luck w/ solving.
Old 05-04-2016, 08:07 PM   #10
Houston , Texas
If the house batteries are completely discharged or disconnected, the BIM will cycle as well. I discovered that when I disconnected the house battery to work on it. I had to disconnect the coach battery to stop it from cycling.
Old 05-04-2016, 10:21 PM   #11
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Agee it could be the BIM if batteries are discharged or disconnected. I've also got the BIM into this cycling mode with house batteries disconnected.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Boxster1971 is online now   Reply With Quote
Old 05-08-2016, 11:32 AM   #12
1989 34' Excella
Sorry, but for the acronym-challenged: What's a 'BIM'?
MohawkDaddy is offline   Reply With Quote
Old 05-08-2016, 12:29 PM   #13
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Battery Isolation Module. A solenoid that connects the house batteries and the starting battery together so they can both charge from the same source, or isolates the house batteries from the chassis battery when there is no charging source in order to keep the chassis battery from being drained along with the house batteries.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-08-2016, 01:59 PM   #14
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I had a propane regulator sound like a water drip on a tin pan. Early morning, running the refer on gas, drove me nuts. I finally got up and looked for the source.
Feel the regulator when it is ticking, if you feel it, you found it. Not an automatic fail, just a cold burp of gas thru the diaphragm. I swapped mine out on noise alone.
"Chip Tank" is in Flagstaff Az.
CDONA is offline   Reply With Quote
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box betsy Airstream Classifieds 0 09-19-2014 11:01 AM
clock not ticking 70s guy General Interior Topics 2 11-24-2010 01:03 PM
Buzzing sound from sound system, walking on floor makes it stop. foqus Electrical - Systems, Generators, Batteries & Solar 9 08-24-2009 08:22 PM
Ticking Sound in Moho grovelander Classic Motorhomes 8 10-17-2007 07:33 AM
ticking time bomb? 2 Winds Waste Systems, Tanks & Totes 4 06-16-2007 09:34 AM
