Old 09-14-2015, 10:55 AM   #1
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
The Solar Solution
I keep reading discussions on this and other forums about house battery problems. In my view the solution is solar. Airstream is behind their competitors in increasing solar panels on the roof to at least 200 watts, which is a level that solves nearly all battery maintenance issues. Of course this also means upgrading to a better solar that the one now provided by Airstream. Since I upgraded my solar to 400 watts I never worry about my batteries, even with the refrigerator running constantly. I started with 200 watts and that was adequate to keep the batteries maintained where I park my van in half day shape behind my townhouse. I increased to 400 watts as I intend to increase my battery capacity to 400 AH so I can do more without hookups.
This solution may not help those that store their Interstates indoors.
Just my 2 cents.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 09-14-2015, 11:51 AM   #2
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
I know you've posted them before, but can you please post some pictures of the roof showing the panels and how you've attached them, and also the solar controller and its display panel.
Thanks!
Old 09-14-2015, 01:18 PM   #3
Fulton , Maryland
Here are a couple of photos as requested.
I used Rhino-Rack roof carries connected to the Mercedes Installed roof rails that came on my 2013 Interstate. I don't think the new Interstates have these now. But there are lots of other ways to mount solar panels on the roof of this van.
The initial 200 watt setup, followed by the final 400 watt panels. Then some photos of the controller and remote panel locations.
ID:	248017   Click image for larger version
Name:	400 watts on AI.jpg
ID:	248019   Click image for larger version
Old 09-14-2015, 01:54 PM   #4
UKDUDE's Avatar
Sedona , Arizona
Thank you Boxster - very neat and professional. Did you remount the Maxxfan? Looks like its facing backwards.
Only 9.5 hours on the generator? That's got to be a testament to the usefulness of good solar and batteries!
Old 09-14-2015, 01:58 PM   #5
k9jackie's Avatar
2015 Interstate Ext. Coach
Great Falls , Virginia
I really like that interior LP switch too!
2014.5 Airstream Interstate Ext.
k9jackie is offline   Reply With Quote
Old 09-14-2015, 02:04 PM   #6
Raymond , Iowa
I have recently upgraded to 200 W wiht MMPT controller and do not see a need for more than that unless/until I increase battery capacity above the standard two group 24's (160AH). I don't want to use more than 50% on a routine basis to give good battery life. Our current (no pun intended) usage of refrigerator, water pump,, and modest use of lighting (no inverter usage to speak of) is about that 50%. And with 200 W I can recharge from 50% on a good sunny day - especially if suplemented with a bit of driving. I am not sure how/why we would use a whole lot more than that (maybe with satellite TV???) so am not in a great hurry to increase battery capacity.
Titus is offline   Reply With Quote
Old 09-14-2015, 03:45 PM   #7
Fulton , Maryland
Yes - that interior LP switch is really helpful. I think it is a must for Airstream to add to their design.
- - Mike
- - Mike
Old 09-14-2015, 03:56 PM   #8
lewster's Avatar
Naples, FL , Hood River, OR
Nice job!
The roof rack structure really isn't necessary with our rocker foot mounting system and 3M VHB tape. NO HOLES!!!!
The only problem now is the very limited availability of AM Solar's GS-100 high efficiency panels. These measure about 20 X 40 and are perfect for AI use. Unfortunately, they are no longer being made.
The smallest 100 watt hard panel is now 21 X 47.
Am Solar has a few left, so if you have any intent to go solar in the near future. I would strongly suggest that you buy your panels now so they will be available when you want them.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 09-14-2015, 03:57 PM   #9
Fulton , Maryland
Yes - I reversed the MaxxAir Maxxfan. It was very easy - just remove four screws and flip it around. I never left the fan open when we drove anyway so reversing it was no big loss. It was required to get the panels mounted in front of the AC unit.
That photo with the generator control panel is a few years old. I now have about 27 hours on the generator and have done one oil change at 20 hours. Still need the generator for AC in the evening during our winter trips to Key West where we boondock on the Navy base. Also used the generator during dinner hours this summer in Glacier NP when we wanted to use the microwave to steam some vegetables. Having capability to run the microwave on a larger inverter is the focus of my next major upgrade that I'm working on this fall when I'm home for the nice weather here in Maryland.
- - Mike
- - Mike
Old 09-14-2015, 04:46 PM   #10
Ron_CA's Avatar
San Diego , California
Nice Job Mike!
Don't they make 250w or 300w panels suitable for roof mounting? like on residential?
Ron_CA is offline   Reply With Quote
Old 09-14-2015, 05:24 PM   #11
lewster's Avatar
Originally Posted by Ron_CA View Post
Nice Job Mike!
Most panels that size are 24 VDC nominal. There are only a few solar charge controllers that will use the higher panel voltage for a 12VDC RV battery system.
In addition, we have found that in a mobile environment, anything larger than 26 x 60 (160 watts) shows excessive flexing and potential damage.
But as always, YMMV !!!
Lew Farber
541-490-6357
Old 09-14-2015, 05:35 PM   #12
Ron_CA's Avatar
OK got it Lew.
What about the flexible panels like the 100w panel on my 2015 which BTW seems to be working well and keeps my batteries charged when on the road.
Old 09-14-2015, 07:48 PM   #13
lewster's Avatar
OK got it Lew.
I have 500 watts of flex panels on m Sprinter service van. You can not bond them directly to the roof, as they exhibit distinct sag between the raised roof ribs. I have to remove them after a week and bond a sheet of .080 aluminum to the raised ribs to form a flat surface and then adhere the flex panels to the aluminum.
After all of that, I still see only 60-65% of the charging capacity from the flex panels as I did from the solid panels. They work.....just not quite as well.
I know that Grape Solar no longer makes them and Renogy had a huge recall on theirs. That leaves Go power, who charges an outrageous price of around $600 for a single 100 watt panel. You can almost get 3 Renogy flex panels for that!
Old 09-15-2015, 10:26 AM   #14
Fulton , Maryland
I bought all four of my 100 watt panels from AM Solar along with the controller and all wiring, lugs and labels.
- - Mike
- - Mike
Airstream solar pre-wiring compatibility with AM solar robi Electrical - Systems, Generators, Batteries & Solar 6 06-11-2014 09:31 PM
Solar Install AM Solar outdoors717 Generators & Solar Power 3 07-15-2012 07:11 PM
A Sewer Solution.... Solution FreshAir Waste Systems, Tanks & Totes 15 09-29-2007 10:23 AM
"sewer solution" Chuck Waste Systems, Tanks & Totes 17 08-29-2002 09:17 AM
