Old 03-17-2014, 11:44 AM   #1
AI owner since June 2013
2014 Interstate Ext. Coach
Lake Mary , Florida
Tank Sensors
The grey water tank sensor on my new AI seems off - shows 2/3 full very quickly even though the fresh water tank doesn't more than 1/3 empty. Are the sensors adjustable or is it possible mine wasn't installed at the proper level?
Dumb question - but what happens if the grey tank is overfilled?
FlaBucki is offline   Reply With Quote
Old 03-17-2014, 12:27 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Tank levels aren't terribly accurate, in my opinion; they're more usable as indicators than actual measurements. If you fill the black and gray tanks untl the red "Full" lights are flickering but not steadily on, it's generally time to dump the tanks but not past time to dump.
There are no dumb questions, unless I'm the one asking them! The first thing you would notice is gray water backing up through the shower drain; that drain is lowest, so it overflows first. Which is good news because the shower pan helps keep the excess water contained, and bad news because if you have to drive to the dump station, it will slosh over the rim of the shower pan.
Handy hint… If your gray tank starts to overflow into the shower pan, shut off the flow of fresh water so you're not making it any worse, and then go outside and open the gray tank valve, WITHOUT turning on the macerator pump. What this will do is drain some gray water into the 4" line between the gray tank and the macerator pump, without discharging any gray water onto the ground. That should free up just enough space in the gray tank for the shower pan to drain back down before you head for the dump station. You should normally drain the black tank first, then the gray tank, but the macerator pump makes it possible to partially drain the gray tank when that tank is trying to overflow, then switch to draining the black tank, before draining the rest of the gray tank.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-17-2014, 12:46 PM   #3
UKDUDE's Avatar
Sedona , Arizona
The sensors are stuck on rather crudely with some sort of rubber mastic. One of mine fell off and the dealer stuck it back on. They are just positioned approximately on the tanks.
The Interstate should be level for a better reading.
Old 03-17-2014, 01:12 PM   #4
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
My gray water tank reads 1/3 full when completely empty and the RV is level. Going to check the sensor placement when I get back.
Old 03-17-2014, 07:41 PM   #5
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Mine also shows 2/3 full very quickly, but the 1/3 full light never comes on. Protagonist's advice is right-on!
- - Mike
Old 03-24-2014, 07:51 PM   #6
Trying to Retire
MILATV's Avatar
Decatur , Illinois
Funny. All my fresh water level gauges fell off on trips this winter - just dangling. I used the grey & black gauges to figure my water level. Hope to figure out how to connect them and in what order this spring.
Mike
If you work until you have everything you 'WANT' - it will probably be too late to enjoy it.
Live in the Moment and enjoy today.
MILATV is offline   Reply With Quote
Old 03-25-2014, 07:52 AM   #7
73shark's Avatar
You could try filling the tank with water about half full. With someone in the coach monitoring the LEDs you could try moving each sensor past the water level to see which LED lights up and determine which one it is by that way. Not sure what adhesive would be best to stick to the tank.
Old 03-25-2014, 08:21 AM   #8
Actually, since the tank sensors are set at the one-third, two-thirds, and full positions— there's no purpose to the one at the "Empty" position; if none of the others are lit, that's the same as the empty light being lit— the thing to do is divide the tank capacity by 3, add one-third and set the one-third sensor, then add another third and add the two-thirds sensor, and then add the final third and set the Full sensor.
Your technique for figuring which sensor is which can be combined with mine for setting the sensors, just using the one-third full level rather than half full to determine which sensor is which.
A Sharpie marker, and a number 0, 1, 2, or 3 for (counting by thirds) on each sensor to tell which is which will help if they fall off again. Same Sharpie marker can be used to mark the tank itself, drawing an outline around each sensor to show where to stick them back on next time.
Note to self: since mine haven't fallen off yet, next time I have my Interstate elevated high enough to get my thick torso under it, I need to mark my fresh and gray tank sensors exactly that way to forestall future problems.
WBCCI #1105
TAC LA-4
Tank Drain Questions Al and Missy Fresh Water Systems 7 02-13-2014 07:18 PM
Belly Open and Troubleshooting 70's Tank Sensors CA_Tallguy Waste Systems, Tanks & Totes 2 09-14-2013 05:07 PM
Grey tank for rear bath '66 TW. FreshAir Waste Systems, Tanks & Totes 15 02-13-2012 09:06 PM
Black water tank valve flange Safari64 Waste Systems, Tanks & Totes 1 09-22-2011 07:50 AM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
