Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 08-19-2019, 07:17 AM   #1
2011 Interstate Coach
Tulsa , Oklahoma
Tank Heater Matt Detached
Has anyone had the tank heater matt become detached? One edge, forward of the tank retainer strap, has become detached and I have tried different adhesives to hold it in place with no long term luck. I have not tried double sided automotive trim tape yet, but it is next unless someone can guide me differently.
Thanks ahead of time.
Road Jager
Living On Tulsa Time
RoadJager is offline   Reply With Quote
Old 08-19-2019, 07:33 AM   #2
Muskogee , Oklahoma
Going on a winter trip?
I would not recommended VHB tape as it adds a bit of insulation between the heating pad and the tank. These heaters don’t get that warm so it would likely degrade the performance.
Try this instead:
https://www.amazon.com/Permatex-8219...s%2C141&sr=8-9
2011 Interstate WD/Lounge (since sold).
2020 Leisure Van WonderRTB
gmillerok1 is offline   Reply With Quote
Old 08-19-2019, 11:09 AM   #3
2018 Interstate Lounge Ext
LV , Nevada
ROAD JAGER - as previously stated by GMILLEROK1 double sided TRIM tape is too thick. But other types of THINNER double sided tape works better. See recommendations on this recent post
Alex AVI is offline   Reply With Quote
Old 08-19-2019, 03:59 PM   #4
2013 Interstate Coach
Idaho Falls , Idaho
My tank heaters on both grey and fresh water tanks were hanging down. I sprayed contact cement on the mat and on the tank, let set for the required time and put together.
Has lasted for 2 years and 24000 miles.
Passin Thru is offline   Reply With Quote
Old 08-20-2019, 09:27 AM   #5
2023 30' International
Galloway , OH
We don't have tank heating pads on our 2016 28FC but our fresh water tank became partially detached and dragged below trailer during a road trip.
Airstream said it is a known issue and is fixing it at their cost even though it is out of warranty.
Airstream of Utah did partial repairs so we could use the fresh water system again. We didn't have time for complete repairs there so we have an appointment at the factory to finnish the repair.
Airstream has been great at supporting their product while we are traveling halfway across the country from home.
Chris
ChrisC is offline   Reply With Quote
Old 08-20-2019, 11:07 AM   #6
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
Mine came undone during the first trip... I used 3M Hi-Strength 90 Spray Adhesive and then some black gorilla tape (same as duct tape) around it... still in place.
Yes, dealer will do it under warranty... I did not have the time to waste waiting for them for such a simple fix. If the actual pad had been damaged, yes, then I would have taken it to get it repaired...
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 08-20-2019, 12:52 PM   #7
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
As others have mentioned, I used the Permagasket (as recommended on this forum when I posted the same problem last year). http://www.airforums.com/forums/f240...ad-182090.html Then I used Gorilla Tape on the leading edge just to ensure it stays in place.
Clean dirt from the detached portion of the pad & tank (don't worry about removing all existing glue), apply the Permagasket and figure a way to hold it in place. I used an inflatable bladder to hold pressure from below over night. If you want to do the Gorrilla tape too, go ahead. You may want to use it on the leading edge of your remaining tank pads since that is where they tend to detach.
rowiebowie is offline   Reply With Quote
2016 Classic: Mirror Detached, Destroyed & Destructive dhroberts 2016 - Current Classic (all lengths) 45 11-16-2016 08:34 PM
Squarestream skin detached matohunter All Squarestream Trailers 6 12-08-2011 03:28 PM
Converter Part Detached BDandTTs Batteries, Univolts, Converters & Inverters 12 07-19-2009 08:36 PM
combination of Acid and Glas Matt batteries Sierrapapa Generators & Solar Power 5 10-25-2007 11:49 AM
