2014 Interstate Ext. Coach
Poconos of Pa
, Pennsylvania
There should be one in the black box behind the right rear wheel. That is where you shut off your propane and refill it. There is a quick disconnect there and there should have been a quick disconnect hose that came with your 2013, maybe.
Finding the low pressure quick disconnect is easy compared to finding a small cheap grill that will operate off the low pressure port. (Do I dare enlarge the hole on the fitting that is designed to be screwed into a high pressure tank? Try successively larger bits until the thing lights and burns blue, keeping one hand on the shut-off valve and the other on a fire extinguisher while I experiment.) Note the empahsis on small and cheap - I don't plan to use it often (the occasional burger or tube steak) and don't want to allocate to much $ or space to something that won't get used much. Am kinda thinking the small charcoal weber might be best for me if only I can find the right sized plastic tub to put it and charcoal in while traveling
Poconos of Pa
, Pennsylvania
If you search for low-pressure portable grilles you should find them. If you check with a good propane dealer (no your local gas station) maybe they can advise you how to connect a low pressure to a regular portable grille. It basically involves removing the pressure regulator on the portable grille to hook up the Airsteream hose, but if you and not savvy, check with someone who it. Remember the old adage: Go Gas, Go Modern, Go Boom! CAREFUL!!!!
Camping World catalogs some low pressure grills complete with mounting bracket to attach the grill to the camper.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
