Old 12-19-2013, 07:21 PM   #1
Newbie
joemikeb's Avatar
2013 Interstate Coach
Fort Worth , Texas
Table pedestal base
My wife hates the table pedestal base just forward of the rear lounge. It does not appear as if there would be any particular problem removing it, but she insists I check with you all before I do so — just in case I am missing something obvious or non-obvious.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
joemikeb is offline   Reply With Quote
Old 12-19-2013, 08:18 PM   #2
Boxster1971's Avatar
Fulton , Maryland
If you remove that base I think you will have a large hole in the floor that will be worse than the table base unless you plug that hole too.
- - Mike
Old 12-19-2013, 08:56 PM   #3
Sebastopol , California
On our 2007 the pedestal was flush mounted so all that was left after removal was 8 screw holes. I put some carpet there and haven't given it another thought.
Sebtown is offline   Reply With Quote
Old 12-20-2013, 06:39 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The pedestal base is surface-mounted over the flooring material. Remove the base and plug the screw holes, and you're good.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
