Old 08-24-2015, 03:02 PM   #1
2016 Interstate Lounge Ext
Heathrow , Florida
Stowaway2.....Not so fast!
If you are looking to increase your storage capability on your AI the Stowaway2 Max will certainly provide much needed space. HOWEVER.....if you have a new AI like my 2016 you should know that it blocks the rear sensors and disables your blind spot monitoring system. If I had known that before the purchase I may not have been so quick to slap it on the back as the blind spot sensor is a great travel tool.
Harleydeal is offline   Reply With Quote
Old 08-24-2015, 03:21 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
My Interstate doesn't have the sensors, so I don't know exactly where they're located. But if they're down by the bumper, then it might be an easy matter to get a 2" or 4" drop hitch, and mount it upside down to provide a 2" or 4" rise for mounting the Stowaway, that might allow the sensors to be cleared.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-24-2015, 04:27 PM   #3
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . great idea Protag, turn the drop stinger upside down. Hope Mr Harleydeal will let us know if that works for him, regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 08-24-2015, 05:59 PM   #4
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
If they're like the ones on my Tahoe, they are mounted in the bumper cover.
With the mirrors adjusted, there should be no blind spots, especially w/ the convex lower mirrors on both sides.
Old 08-25-2015, 08:07 AM   #5
Heathrow , Florida
Good thought Protag but the problem is by raising the assembly up two inches the rear doors would be rendered inoperable.
Old 08-25-2015, 08:27 AM   #6
Heathrow , Florida
Shark.... True that there are no blind spots.... But there is nothing like a bright red triangle to tell you not to bother checking your mirrors because it's a no go. It is a great safety feature that I have come to rely on in my other Mercedes vehicles. It comes in very handy on night trips and reduces the amount of squinting at the glaring lights in your mirrors.
Old 08-25-2015, 09:08 AM   #7
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
I doubt that raising the box 4" is going to be enough. Those sensors have a wide field of view. But then again it's worth a try.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 08-25-2015, 12:01 PM   #8
If I had those triangles in our Interstate, I would NOT want to lose them. We rented a 2015 Ford Somethingorother earlier this month that had that technology (I hadn't seen it before), and while I think it might be overkill for a car, it would be very useful on a larger vehicle. We put side cameras on our Interstate to help with lane changes, but they do have the obvious lighting limitations due to exposure adjustment lag time (glare / darkness). Some of the new automotive tech features fall squarely into the bells and whistles category, but I think the triangles are a keeper. Would pay for them, yes.
InterBlog is online now   Reply With Quote
Yikes! No Idle Adjustment - Fast Idle. lebolewis Tow Vehicles 97 08-27-2006 05:20 PM
furnace fast cycling - thermostat adjustment emanon25 Furnaces, Heaters, Fireplaces & Air Conditioning 2 09-28-2004 09:06 PM
How fast do you usually drive? joshua32064 On The Road... 30 02-21-2004 02:25 PM
Fast Tire Source Jabba Tires 0 07-09-2003 07:34 PM
