Old 03-10-2015, 03:57 PM   #1
Glamper1's Avatar
Stove venting
When using your AI stove, how do you deal with steam and smoke?
Seems like an above stove exhaust system is needed.Click image for larger version
Glamper1 is offline   Reply With Quote
Old 03-10-2015, 04:52 PM   #2
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Smoke or steam will set off the smoke detector. So I usually open the roof vent; if the steam or smoke or smell is bad, I turn on the fan. If it gets too bad I also open a small window to create a through-flow of air out through the roof vent.
Old 03-10-2015, 04:55 PM   #3
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
I open the small window next to stove and the roof vent with fan on. This clears the stuff from stove OK. If I forget then the smoke alarm goes off - a good test. 😊
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 03-10-2015, 04:56 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
When I'm cooking on the stove, the tip-out window behind the stove is open, and the MaxxFan is open and turned on. With fresh air coming in the window and smoke/odors going out the roof vent, I almost never have a problem with steam or smoke.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-10-2015, 05:14 PM   #5
Glamper1's Avatar
Even boiling water with roif fan and windows open causes alot of moisture directly above.
Obviously ill live with it but its an odd design I think
Old 03-10-2015, 05:18 PM   #6
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Yep, yep & yep. You can also run the bath fan for extra venting.
Ron_CA is offline   Reply With Quote
Old 03-10-2015, 05:40 PM   #7
Originally Posted by Glamper1 View Post
The MaxxFan is multi-speed, and you may have to run it faster to give it more power to draw off the steam. But don't open all the windows, just the ones behind the galley; you want to create a breeze that blows right past the stove. The other windows should be closed.
WBCCI #1105
TAC LA-4
Old 03-11-2015, 06:45 PM   #8
...aaaaand the smoke detector goes off every time I make toast no matter what I open or how I vent. So don't think this is unusual if it happens to you.
Venting! ArtStream Roof Vents, Skylights & Fans 16 03-31-2009 12:34 PM
Propane tanks venting! Resorts LP Gas, Piping, Tanks & Regulators 20 06-22-2007 07:36 AM
Replacing cooktop with oven - venting issues??? Alumatube Stoves, Ovens & Microwaves 2 03-30-2007 08:10 AM
1960 fridge venting Safari Tim Refrigerators 19 01-30-2007 10:24 PM
Refer heat / venting JaceBeck 1999 Safari 3 08-21-2003 09:40 PM
