Old 05-01-2016, 07:34 PM   #1
Jeff
jkinglet's Avatar
2013 Interstate Coach
Seattle , Washington
Images: 37
Stove burner ignition
Anyone have a clue why without shore power all of a sudden I get no spark to the burners with the electronic igniter. Plenty of spark with the igniter if the AI is plugged in? Fuse perhaps?
jkinglet is offline   Reply With Quote
Old 05-01-2016, 07:47 PM   #2
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
That's pretty odd. If this is the original cooktop, then it uses a pushbutton piezo igniter which uses no external power. Mine failed a couple of years ago and rather than replace the igniter, the dealer replaced the complete cooktop.
Old 05-01-2016, 07:50 PM   #3
Alcoa Roller's Avatar
Dallas , Texas
My cooktop is modern and the spark comes from 12 volt. Could be you have a 12v switch in
off position or possible bad battery ?
Alcoa Roller is offline   Reply With Quote
Old 05-01-2016, 08:07 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I don't believe there is an electrical connection to the stove; piezoelectric igniters don't require them.
Mine only works intermittently. But since I carry a butane grill lighter anyway, I just use it to light my stove burners and don't even bother with the piezoelectric igniter anymore.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-01-2016, 08:15 PM   #5
Jeff
jkinglet's Avatar
Images: 37
yep, original cooktop. Odd to say the least why it worked on shore power and not otherwise. same igniter. maybe coincidence?
Old 05-01-2016, 08:17 PM   #6
Jeff
jkinglet's Avatar
Images: 37
I hear ya. thanks.
Old 05-02-2016, 08:35 AM   #7
Boxster1971's Avatar
Fulton , Maryland
Concur - the piezoelectric igniter it hit or miss. I often have to press it many times quickly to get the burner to lite.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Gas Stove With Electronic Ignition ttbikes 1959-69 Tradewind 2 05-08-2015 08:53 AM
Freestanding LP Stove with Piezo Ignition VAbirdwoman Stoves, Ovens & Microwaves 1 07-31-2012 08:44 AM
Stove-top burner tubes wacnstac Stoves, Ovens & Microwaves 17 06-03-2010 06:35 AM
Two Burner Stove Foiled Again Full-Timing 2 11-17-2007 10:32 PM
