Old 07-09-2015, 09:28 PM   #1
2005 22' Interstate
N. Hollywood , California
Squeaky wheels ??
I am hearing a "rotating" or pulsing squeak but only when the windows are open and when we are near a wall or mountainside where the sound bounces back to me.
From the drivers seat it sounds like it is coming from the passenger side , perhaps one of the wheels.
I opened the hood when stationary and checked for belt/pulley noises.
I think I need to get myself a floor jack and stands and inspect the brakes.
Any suggestions or comments ? It is a 2005 AI. It has only 59k miles and original brake pads.
Cheers
Colin
mrcolin2u is offline   Reply With Quote
Old 07-10-2015, 04:51 AM   #2
Rockwell , North Carolina
I would suspect a faulty wheel bearing.
jerhofer is offline   Reply With Quote
Old 07-10-2015, 05:26 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Could very well be a hubcap moving against the rim. If your motor home has them, try removing them, and driving it, and see if the noise goes away.
Old 07-10-2015, 06:35 AM   #4
2005 22' Interstate
I was also thinking wheel bearing , although I've never actually heard what a faulty one sounds like.
I wonder how difficult they are to change?
Old 07-10-2015, 06:37 AM   #5
2005 22' Interstate
I don't have hubcaps , the wheels are alloy. Wish it was that simple though
Old 07-10-2015, 08:02 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
Disc brake ware sensor rubbing on rotor?
Old 07-10-2015, 09:49 AM   #7
If it is a wheel bearing issue, you will want to find out right away. If a bearing seizes, you could lose a wheel. Not a good thing to happen at speed!! You could take your unit to a tire shop to have them check it out.
Squeaky wheels ?? 73shark Sprinter and B-van Forum 13 01-09-2016 11:24 AM
squeaky heater.... cnsilver Furnaces, Heaters, Fireplaces & Air Conditioning 0 10-31-2008 04:53 PM
Which squeaky wheel should get the oil first. Aluminati General Repair Forum 11 10-17-2007 06:48 PM
squeaky floor clintn 2005 and newer - Bambi all models 2 04-18-2007 10:17 PM
Squeaky axles - are Henschens quieter? AlbertF Axles 5 11-17-2006 02:09 PM
