Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 12-12-2019, 07:51 PM   #1
2017 Interstate Grand Tour Ext
barrie , Ontario
Sprinter engine battery failed and Fusion “confusion”
After three years our engine battery would no longer hold a charge. It was replaced in Pensacola at the Mercedes dealer who was very gracious and got us into their booked up schedule.
Mercedes did a battery diagnosis and determined the battery was pooched. It also diagnosed a 1.1 amp parasitic draw on the battery but the source wasn’t located due to time constraints. For now they recommended we use the battery disconnect by the gas pedal whenever we stop for an extended time until the load is determined. Mercedes suggested that it was not a Mercedes cause but an add on from Airstream.
Coincidently there has been an unusual thing happening with the Fusion System. When we are on shore power and the battery is disconnected, every time the transfer switch changes and the inverter goes into a charging cycle the Fusion turns on ??? even though we always shut the radio off and hit the power button twice. It happened three or four times last night. It seems that once a charge cycle starts it sequences the whole electrical system.
Has anyone experienced this or have suggestions.
catjer is offline   Reply With Quote
Old 12-12-2019, 09:31 PM   #2
StreamingAI's Avatar
Judson , Texas
I've had nothing but battery trouble since I bought my 2017, about 3 months ago. It had 3600 miles on it and all battery's were in bad shape.
There are several old threads on this. First I put the Fusion on the
House power.
If you pull the radio out you will see the wire spared in the wiring nest. It is currently on a 10 amp fuse from the chassis battery. The drain is coming from the signal wires. I then replaced the airstream installed ACR with the Blue Sea ML ACR that comes with a remote switch. I replaced the Pushbutton start assist with the blue sea toggle switch.
If parked with shore power, I put the switch in "manual. Driving in "auto". Parked and no shore power "off". Working perfect. There is a pic on one of my posts of the switch.
StreamingAI is offline   Reply With Quote
Old 12-14-2019, 07:05 AM   #3
2018 25' International
Slidell , Louisiana
Sounds like a voltage spike occurs when the converter cycles into charge mode. Add in the parasitic load and I'd want to suspect the two issues are related. It is possible the rapid voltage change causes the Fusion to trigger its internal low/high voltage protection circuitry causing the thing to "reboot" in the on position. I have seen this many times in my line of work with industrial controls and instrumentation containing digital circuitry.
So on the assumption the two issues are related, I'd disconnect/isolate the converter first and then the fusion next to try to locate the source of the parasitic load.
Good luck!
Old 12-14-2019, 11:07 AM   #4
Judson , Texas
catjer Go to Battery Isolator- Replacement Help page 2 as it has a lot of info.
about the Blue Sea Isolator.
My pic is on page 3 on the post
Fusion battery drain Mansderm161 Sprinter and B-van Forum 14 10-01-2020 05:53 PM
Airstream Interstate engine A/C failed Mickey2012 Furnaces, Heaters, Fireplaces & Air Conditioning 0 09-12-2019 05:53 PM
For owners with the Fusion Infotainment system - battery saving tip FlyFishinRVr Sprinter and B-van Forum 0 04-20-2017 07:30 PM
2016 23' Flying cloud battery and holding tank monitor failed sunmoon9x6 General Repair Forum 1 04-22-2016 10:55 PM
Site for Sprinter & Sprinter-based RV Enthusiasts Zach Woods Sprinter and B-van Forum 0 09-25-2006 04:08 AM
