Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 06-02-2016, 09:35 AM   #21
"Cloudsplitter"
Question How about.....
Originally Posted by BTB View Post
You folks are so funny - 200 gallons indeed!
So "de-ionized water" is Reverse Osmosis water. Water is forced by pressure through a membrane with vewy vewy tiny holes in, so only the water, and not the salts and other stuff can get through. So when the water dries, nothing is left behind, i.e. no spots!
Same thing as under your sink.
The 100 gal or 300 gal will be a supposed measure of how many gallons per day the system can produce.
Toweling dry has the same effect, as virtually nothing is left on the vehicle to evaporate and leave pounds of salts behind.
.......water from the AC? It must be worth something.
Old 06-03-2016, 07:10 AM   #22
BTB
San Diego , California
Condensate from the A/C is essentially distilled water - should be fairly de-ionized - worth a try.
BTB is offline   Reply With Quote
Old 06-03-2016, 08:01 AM   #23
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Just how much condensate does your A/C produce?
Old 06-03-2016, 12:21 PM   #24
Mr. B's Avatar
2015 Interstate Ext. Coach
Lake Mary , Florida
Haha )))
Free spotless car wash... on the 1st of September every year.
Mr. B is offline   Reply With Quote
Old 06-03-2016, 01:55 PM   #25
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
In NOLA in July, probably a lot.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
Old 06-03-2016, 02:21 PM   #26
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
The CR system seems like an expensive way to do an easy job. I've won Porsche Concours events with no fancy equipment, just a bit of elbow grease.
John Audette
Air Cooled Porsche Specialist -
Two roads diverged in a wood, and I took the one less traveled. ~ Robert Frost
John&Vicki is offline   Reply With Quote
Old 06-03-2016, 03:22 PM   #27
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Roughly a dollar a gallon for DI water. You could use RO water from your under-sink unit for only the very final rinse to achieve much the same result.
Old 06-03-2016, 06:47 PM   #28
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
A spotless car wash must be something you owners of black vehicles worry about.
I washed my silver Interstate yesterday to get it clean, photo below. Today it rained most of the day and it sits outside. I never worry much about making it spotless as with 67,000 it has more than a few dings now.
Name:	ImageUploadedByAirstream Forums1465001191.083838.jpg
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Old 06-03-2016, 07:20 PM   #29
Mr. B's Avatar
Lake Mary , Florida
Silver is different.
I like you batteries, Mike.
And what is a rounded on your AC cover?
Old 06-03-2016, 07:27 PM   #30
73shark's Avatar
TV antenna
Old 06-03-2016, 07:36 PM   #31
Mr. B's Avatar
Lake Mary , Florida
Interesting. What is the kind?
Old 06-03-2016, 07:46 PM   #32
Originally Posted by Boxster1971 View Post
Did you rotate your MaxxFan hood 180 degrees? It looks like it opens to the front instead of the rear.
Old 06-03-2016, 07:52 PM   #33
73shark's Avatar
It's the original one that used to reside on a tripod where the rear solar panels are now. He mounted on top of A/C w/o the tripod.
Old 06-03-2016, 08:03 PM   #34
2024 Interstate 19
Fulton , Maryland
Yes it can be flipped 180 deg very easily by removing four screws that hold the core unit to the mounting frame that is attached to the vans roof. I had to flip the MaxxFan to make room for the solar panels in front of the A/C unit. Only limitation is I don't leave it open when driving. I newer left it open anyway since it puts a lot of strain on the mechanism.
- - Mike
- - Mike
Old 06-03-2016, 08:12 PM   #35
2024 Interstate 19
Fulton , Maryland
Right on 73shark - it's a Winegard omni directional antenna that they don't make any longer. I think the replacement is a Roadstar model on newer Interstates.
http://www.winegard.com/roadstar
I moved the antenna after I saw Lew Faber do it to make room for more solar behind the A/C unit. There are other solutions using a smaller antenna, but I wanted to work with what I had and it works very well.
- - Mike
- - Mike
Old 06-03-2016, 10:34 PM   #36
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, deionized water does work. This is what was used at one of the Ford dealers that I worked at. In Southern California the Sun could dry your car faster than a chamois or towel leaving water spots that are very difficult to remove. Sometimes the water spots can't be removed. The lot men could go down the line and wash every car on the lot, one right after the next, and not worry about damaged paint jobs. I would love to have one, but for the cost, I just learned to wash when the weather was just right. In the morning before full Sun or in the evening as the Sun is nearly setting. And dry them fast.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 06-04-2016, 12:16 AM   #37
Mr. B's Avatar
Lake Mary , Florida
I also paid attention for it but thought wanted to ask him later.
- - Mike
Yes there are two screws in metal holders on each side keep the fan unit. Simple to remove and insert back when putting more black silicone around the unit to patch leaking on a new vehicle haha ))) But it is probably to the AI FLAWS thread
Waiting for my 100 Gal unit next week
Acid wash or no acid wash? alan.aliciac 1959-69 Tradewind 10 09-04-2015 10:12 PM
2006 airstream safari 23ft*spotless*extras* eBay Watch Airstreams on eBay 0 05-21-2010 09:10 AM
2006 airstream safari 23ft*spotless*extras* eBay Watch Airstreams on eBay 0 05-01-2010 02:10 PM
Hand wash VS power "car wash" TommyL Cleaning, Stripping & Polishing 2 04-12-2010 02:50 PM
coin car wash wax david h Our Community 1 01-13-2003 08:27 AM
