05-28-2016, 07:38 PM
2015 Interstate Ext. Coach
Chicago
South Dakota in October
What's the likelihood of below-freezing temps around Mt Rushmore Mid-October? We are thinking of a more northerly route (vs. our usual I-40) in driving from Chicago to S Cal for the winter. We'd head to Mr Rushmore around mid-Oct; then dive south through Vegas on the way to Palm Desert.
Anyone with experience there that time of year?
THANKS
05-28-2016, 08:05 PM
2012 20' Flying Cloud
Bishop
I just got back from Mt. Rushmore last week. I had temps in the 20s at night. I would guess below freezing is possible in mid-Oct. There is a very nice commercial RV park just outside the main entrance into Mt. Rushmore. With full hook-ups, you should have no problems with low temps.
Good luck,
Bill
05-28-2016, 08:19 PM
2011 Interstate Coach
Overland Park
, Kansas
Be sure your tank heaters are on. And don't run your macerator pump 'til you are in warmer climes long enuf to thaw it out. Or you could put some RV antifreeze in the pump before you leave.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
05-28-2016, 08:26 PM
2012 25' Flying Cloud
Battle Lake
Mid October is about the time our overnight temp's began dipping below freezing. On the average, and most years are a little above or a little below average, you never know.
It's the time of the year we hook up our Airstream and look at the weather map to see if our preplanned trip to the south for the winter is going to work. If not we head toward the Plan B trip. The idea is to take a different route each year, if headed to Arizona we may see Florida or Washington State first.
We have not ever winterized this Airstream, our goal these days is to keep out of winter. We have often opened all the drain valves and let the tanks and lines self-drain, a little interior heat keeps us and the remaining interior lines from freezing.
Chances are you'll be in the winter transition period, and it will swing either way a bit. Head west to Mt. Rushmore as planned, you most likely be fine and may hit that wonderful and short moment called indian Summer. With an eye on the weather forecast keep going west to the coast if you like, it's a great trip, be prepared to make a left turn if it isn't.
Doug and Cheryl
05-28-2016, 09:31 PM
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie
I've pheasant hunted in South Dakota for the last 10 years mid to late October. Though considerably Southeast of Mount Rushmore, we have seen a little of everything over the years. More than half of the years the temps have been great in the days with the lows near freezing. Could go either way though.
As Doug mentioned earlier, keep an eye on the weather forecast and go on and go as a good chance you will have some fantastic mid 60's days with nights getting near freezing. If worse is forecast, cut the trip shorter and keep heading West. Enjoy your trip and safe travels.
Chuck
05-29-2016, 01:28 AM
Salem
, Oregon
Hi, several years ago we went to Custer, South Dakota in October. It was Zero degrees at night and a high of 27 degrees during the day. We filled both propane tanks in Wyoming and sure glad that we did. We almost completely used up all of our propane in about five days. We ran our furnace 24 hours a day until we got out of this area. Our camp ground had 120 spaces and we were the only ones there. We also drove on snow and ice with two wheel drive and no chains.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
05-29-2016, 08:54 AM
Bellevue
And here we are, wondering if we will use our new Interstate when it is 30 to 40 degrees F in winter time. Thanks for posting that. Gives me motivation to use ours all year around.
05-29-2016, 09:05 AM
Waxahachie
Sounds like you hit the year they had the horrible storm come through. Tons of cattle were lost. The fickle October weather in SD. Glad you came through it all OK.
Chuck
05-29-2016, 09:10 AM
E Pluribus Aluminus
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Land Of Enchantment
, New Mexico
Didn't get the memo, huh?
Jaxon
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
05-29-2016, 09:20 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
I've used my Interstate for winter camping. Admittedly winter camping in the South, but on one trip while I was still working… It was New Year's weekend and I took a vacation day to give myself a four-day weekend. I went to Poverty Point State Park, Louisiana. After the first day, the temperature dropped below freezing and stayed there— for the last three days of my trip the high temperature was 27°F, contrary to every forecast for the area that all predicted the overnight lows were going to be in the 30s for that weekend.
I had full hookups, but wisely took the precaution of filling my fresh tank and bringing my hose inside so it didn't freeze. Tank heaters and furnace kept things warm enough for comfort, but I couldn't dump my waste tanks during the trip due to the macerator pump freezing. That had to wait until I returned home to above-freezing temps. Even though the macerator pump froze, there was no damage to it— fortunately I had run it dry the previous time I used it, so there wasn't enough liquid in it to expand enough to break anything.
05-29-2016, 09:40 AM
Bellevue
Good to hear more stories of winter travel. So is there no good solution to using the macerator pump in cold weather? I read about putting anti-freeze in there but is that an easy thing?
05-29-2016, 09:55 AM
2016 Interstate Lounge Ext
Heathrow
Maybe there is a way to wrap macerator with electrical heat tape?
05-29-2016, 10:20 AM
TinCan
2016 30' Classic
Apache Junction
October might be a little too chancy for me. Pretty much allergic to cold weather.
TinCan
05-29-2016, 10:48 AM
From All Over
As far as I'm concerned, Airstream ought to do it at the factory as a standard feature, with it wired into the tank heater circuit.
But a do-it-yourself solution certainly should be doable.
05-29-2016, 10:53 AM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
When we travel up north in the fall, we are always flexible when it comes to weather. Last fall, we took off in mid-Sep with the idea of making the Tetons by late Sept and kayaking in front of golden aspens and on blue lakes. The weather held, and it was perfect. We even camped at Bryce in early Oct.
But we were always ready to head south if the weather appeared to get too cold. There's always someplace great to go.
So - make your plans and bail if you have to. If you put too much faith in long-term weather reports, you'll never go anyplace.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
05-29-2016, 11:04 AM
2024 Interstate 19
Fulton
, Maryland
I agree with you. When I got home to Maryland in March from our month in Florida we got a stretch of freezing weather. I didn't want to winterize again so I ran a heater inside, turned on the tank heaters and wrapped the macerator and exposed sewer line with 120VAC heat tape.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
2024 Interstate 19
Fulton
, Maryland
Pat
Pat - this is great advice!
- - Mike
- - Mike
05-29-2016, 01:04 PM
Muskogee
, Oklahoma
... Even though the macerator pump froze, there was no damage to it— fortunately I had run it dry the previous time I used it, so there wasn't enough liquid in it to expand enough to break anything.
It is not possible to run it dry, and likely was half full of liquid-it just was not cold enough to freeze. The only way to remove all the liquid is to remove the hose from the pump. Learned that lesson the hard way.
You simply can't pump half air and half liquid uphill. There is always about three quarts of liquid once the level falls about half-way the height of the hose-when it states to sputter after draining the tank-because of the poor design of the waste disposal system itself.
You were likely just lucky more than likely than anything else.
2011 Interstate WD/Lounge (since sold).
2020 Leisure Van WonderRTB
05-29-2016, 03:14 PM
Overland Park
, Kansas
Drain the gray water tank and then put a gallon of RV antifreeze in it and pump it out. That will leave some antifreeze in the pump and even if some water was left, the dilution should be negligible.
05-29-2016, 03:58 PM
From All Over
I won't argue the point. As a mechanical engineer I have some familiarity with pumps, and I know that the macerator pump wasn't completely dry. When I typed "I ran it dry" what I meant was "I ran it until it started sucking air."
In any event, the macerator pump was frozen, enough that I couldn't even turn it manually in either direction. The following week when I went to a dump station in above-freezing weather the pump worked just fine without having to turn it manually, so the only thing jamming the pump before must have been ice on the inlet side and not any other kind of debris.
And yes, it was probably pure dumb luck— I never have smart luck! — that there wasn't any lasting damage.
