Old 07-06-2016, 08:02 PM   #1
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Solar Panels on Rhino-Racks
I promised fspeier more details on my solar panel installation on Rhino-Rack Cross bars. I thought Id start a new thread to keep from polluting the tread on bought Interstate 2012 - needs a lot of parts.
Here are few more photos. The brackets I made to provide a mounting point next to the Awning are not an original idea by me. I copied the idea from a single photo posted by the Sprinter-Store some time ago. First photo is of the aluminum flat pate adapters made by the Sprinter-Store.
The rest of the photos attached are shots showing some details of the Rhino-Rack legs attached to the brackets when I was fitting the parts. All the final install fasteners were stainless steel with nylock nuts and anti-seize lube added.
Name:	Roof Rack Mount with Awning.jpg
ID:	266151   Click image for larger version
ID:	266153   Click image for larger version
Old 07-06-2016, 08:25 PM   #2
Fulton , Maryland
More details
This post has some additional photos of my fit checks of the Rhino-Racks on the roof of my van. The third photo shows the clearance from the bath vent using my level across the rack bars. The last photo is the new lower 360 Siphon vent I installed to clear the solar panels. I didn't worry about the white color of the new vent compared to the original black as it is not visible.
ID:	266157   Click image for larger version
ID:	266161   Click image for larger version
Old 07-06-2016, 08:43 PM   #3
Fulton , Maryland
Final Installation
These are photos of the trimmed for length Rhino-Rack bars. Then the installation of the first two 100 watt panels in 2014. The last photo is the final four 100 watt panels installed in 2015.
ID:	266174   Click image for larger version
Name:	400 watts on AI.jpg
Old 07-06-2016, 08:47 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
Nice work!!
I see you reversed your MaxxFan. Be real careful that you don't leave it open when you travel, as the cover WILL be sucked right off the roof. I have seen it happen more than once!!!
Old 07-07-2016, 06:30 AM   #5
toskeysam's Avatar
Townsend , Tennessee
Looks great! Curious about your route for wiring to the controller.
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 07-07-2016, 08:26 AM   #6
Fulton , Maryland
Originally Posted by lewster View Post
Nice work!!
Yes I never leave it open while driving. I assumed it would get ripped off in the speeds above 30 mph.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 07-07-2016, 11:45 AM   #7
Bellevue , Washington
Very nice! When you moved the antenna, did you have to plug any holes? Not sure how that is mounted.
amirm is offline   Reply With Quote
Old 07-07-2016, 04:30 PM   #8
Fulton , Maryland
Yes there were holes to fill for both the old 50 watt solar panel (4 holes) and the TV antenna tripod mount (3 holes). I used Sika Sikaflex 221 sealant that I got from Airstream. I filled the holes with sealant and then placed a small patch of duct tape over the holes and covered the patch with sealant.
The newer Interstates have a small TV antenna that might be easier to relocate. I also considered going to a Winegard Rayzar like the link below. But the now discontinued black disc Omni antenna works well and I wanted to keep it.
http://www.winegard.com/rayzar
Old 07-07-2016, 07:30 PM   #9
Thanks. I still have the same fear I had when I had to drill the first hole into my boat. Seems less critical with an RV roof as it is not as visible as a boat and consequence of a leak as dramatic!
Did I read in another thread that those roof rails don't work in the newer Interstates?
Old 07-07-2016, 07:41 PM   #10
2015 Interstate Grand Tour
Mount Washington , Kentucky
Boxster,
Your conversion was my inspiration to do mine, thanks for sharing your posts last year.
jp
JayP is offline   Reply With Quote
Old 07-07-2016, 07:52 PM   #11
lewster's Avatar
No need to drill any holes to mount those panels!!!
I mount 4 X 100 watt panels on almost every AI installation that I do and there is only ONE HOLE.....and that's to get the solar charge line into the coach from the bottom of the roof combiner box.
VHB tape and SikaFlex have all of the bond strength that you need for a Sprinter's roof.
PS: I don't use racks either!!
Old 07-07-2016, 09:06 PM   #12
Fulton , Maryland
I think Airstream stopped ordering their base Sprinters with the roof rails from Mercedes. But there are a lot of ways to mount Solar panels on the roof of your Interstate. Lewster mentioned one of them in his post above.
- - Mike
- - Mike
Old 07-07-2016, 09:08 PM   #13
lewster's Avatar
Nope!
No more rack rails on the newer Interstates. The contact points are still there as these are standard with every Sprinter body. You would have to order the rails from Benz and then install them into the contact points.
Old 07-07-2016, 09:11 PM   #14
Fulton , Maryland
Originally Posted by JayP View Post
Boxster,
jp
Nice job! Looks like you used the AM Solar mounting feet. I would use those if I ever do another solar install on an RV. My installation got a little too complicated. I blame my Aerospace background for over designing it, when I could have just done it like yours.
- - Mike
- - Mike
Best Quality Solar Panels & Solar Controllers to use | Opinions Wanted BoldAdventure Generators & Solar Power 54 03-17-2016 06:04 AM
Anyone tried Rhino Lining as flooring? tvanwave Floor Finishes 1 09-20-2010 09:11 PM
Rhino Liner in bathroom boatdoc Upholstery, Blinds, Walls & Interior Finishes 41 04-14-2010 02:59 PM
Rhino lining on trailer Ball_Park145 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 12 04-04-2007 05:24 AM
Rhino HB Immobilizer luckydc Our Community 0 04-11-2004 10:07 AM
