Hi
Ok, 50W is the panel under crazy ideal conditions. Under "normal" conditions you probably will not see > 80% of that.
You charge your batteries through a DC/DC converter. It *might* be 90% efficient. It could be a lot less.
Battery charging takes place at ~ 13.7V. If your panel is delivering 36W to the battery, that's a bit under 3A. If you get good sun 8 hours a day, that's pretty normal. Net would be 24AH.
Put a good layer of dust / dirt / bird stuff on the panel and your 24AH becomes < 20 AH....
If your batteries are seeing a 1A phantom load, that's going to be 24AH. Things like propane monitors, inverter inputs, control panels all are suspects. That light Bob forgot to turn off when he pulled the chair out of the outside locker is a real good candidate as well. (Hint: look around the trailer at night ....).
So, yes, a lot of numbers and none of them hard and fast. If you have a bit of shade, scale the solar back a bit. End of June in the Arizona desert, scale it up a bit. Could your phantom loads be a bit less than an amp - sure. Could they be a bit more - yes indeed.
First step is to spend some quality time with a current meter to figure out how much current it going where. Next step is to disconnect them and see if the solar controller / charger is still working. It should pull the battery up to 13.7V if it's doing it's thing ....
Lots of fun !!
